4ohm vs 10ohm speakers
Car: 1987 Z28 with iroc-z Package no.3
Engine: 350TPI
Axle/Gears: 3.73 posi
whats up with them i ordered a replacment set and thier 4ohm and my old ones where 10 ohm whats the difference here???
Car: 1991 Z28 Vert
Re: 4ohm vs 10ohm speakers
The difference is the amount of resistance they present to the amp...whether that amp is in your head unit or external. Replacing a 10 ohm speaker with a 4 ohm speaker can be bad news for your equipment. Your new speakers have less than half the resistance of the originals so they will draw twice as much current. Doubling the current drawn through your radio means almost certain death. At very least it will dramatically reduce the life span of your head unit.
To be honest though, most of the 10 ohm speakers I've seen usually came out of older cars. Weird.
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Since you have the 4 ohm speakers...it's the perfect time to upgrade the head unit a well
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Understand that most units are rated when running wide open, where they usually are distorting beyond intelligible audibility. The 4ohm speakers at 1/2 volume will probably sound better, just because the amp will be making more power at audibly clean and clear levels.
The above quote would be correct at levels where the volume is all the way open, for extended periods of time, but for normal use, you should be fine....
Car: 1991 T/A GTA H/T
Axle/Gears: 3.23 Posi
i did not know that but it makes sense. at what point do you think someone should start running a capacitor? opinions?
It never hurts to run a capictor, protection is good, again, that is a general question, specifics would help. But if you are gonna listen loud for long periods of time, components, (amps , speakers, wire) build heat and resistance, capictors help as inline protection... In other words they are usually a good idea!
Car: 1987 Trans Am
Engine: LQ9/L92
caps are strictly a band-aid for an electrical system and does not solve the inherent issues.
First, you should have had 4 ohm speakers to begin with, so something was changed before you got the car. most car audio speakers are 4 ohm and most decks/amps/etc are meant to handle them with ease.
second, do you have an amp or just running off the stock deck?
finally, if you're going to upgrade your setup, then the first thing you should do is upgrade the big 3. it will allow more amperage to flow throughout your electrical system and reduce voltage drop when it comes to musical passages that require more power (heavy bass mainly).
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
I had the dash pad off last week and took a look at the original factory speakers. They said 10 ohms on the backs of them.
I'd definitely recommend the InnovativeWiring.com battery cables for anybody, even if they have a stock stereo.
4 ohm speakers shouldn't be a problem for any car stereo.
