whats better?
Car: 1991 Camaro RS
Transmission: 700 R4
Re: whats better?
cvx is better than cvr. Check out www.kicker.com and it will give you lots of info on each sub. Kicker is a great company. The regular comps are the bottom of the barrel but for the price and quality you just can't beat them.
Car: 1982 Z28
Engine: Stock 305 4BBL - New QJet
Axle/Gears: Stock
Re: whats better?
depends on the rms rating or both the subs and amp? its not what you do...its always how you do it... u can grab a 1200 watt amp and set a cvx's that rms at 450... i can get old kicker cvr that rms a 600...same amp, and still "wham" as loud if not better...
when u do shop...try not to be impressed by their advertised wattage or peak/max power...look for "RMS" and youll be ok...
