Sail panel subs and the rattling gas cap
Car: 92 Camaro
Engine: 3.1
So I just put some pioneer 10's in my sail panels and now the gas cap rattles like crazy.Pretty lame I thought there would be more problems with other parts of the car being noisy but noooo had to be the stupid gas cap.So my question is does anyone know of a good locking gas cap that stays on tight?Thanks.
Re: Sail panel subs and the rattling gas cap
Well at least you can thump your way down the raod if you run out of gas!!
We have whatever * AutoZone * sells on 1 of our other cars. Thing is with this one-- some times you turn the key left to unlock it, some times to the right
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Try applying some sound deadener (ie Dynamat Extreme) behind the subs. It will reduce the vibration.
Simple fix.
Simple fix.
Car: 92 Camaro
Engine: 3.1
I have peel n seal in it but I only did one layer,was thinking about doing another.Its just really annoying.I was also thinking about Spray foaming it a little more and re cutting it and fiber glassing to make it more rigid.Dont know if that would help though.
Car: 1983 Camaro Sport Coupe
Engine: 2.8L, hopefully upgrading..
Transmission: BorgWarner T5, Made here in Muncie
Axle/Gears: stock
Peel N seel will help only a little bit. You're best bet if you are going to take the time to do it is to do it right. I either recommend Dynamat Extreme or Second Skin Damplifier Pro. Preferably the damplifier pro. But you need to do that whole area there well.. I have Rockford Power series 6x9s in my sail panels with about 80 watts going to each and a full layer of second skin pro, and it still rattles a little, i'm going to go through and do another layer.
1992 Trans Am
05-10-2023 07:19 PM
