Speaker Question
Car: 1987 Z28
Engine: 350 L98 interals with Roller Cam
Transmission: T5 Borg Warner non world class
Axle/Gears: 373 posi
Speaker Question
Is there any place in my 87 camaro that would fit a pair of 5x7 alpine s series?
thanks
craig
thanks
craig
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: Speaker Question
Yes...where the 6x9's go in the sail panel.
Car: 1987 Z28
reason why 5x7 is that I have them and don't feel like buyin somethin else when the 5x7 are just sittin around plus with the set up I have now the 5x7 would be an improvement
Car: 1987 Trans Am
Engine: LQ9/L92
Guessing you had a Ford before? Only place I ever saw 5x7's as a stock size (had a Taurus at one point that used em myself). You should be able to use the factory metal mounting bracket to trace a new template to mount the speaker to the car with.
db057
08-11-2015 10:11 PM
