HELP ME PICK AN AMP
HELP ME PICK AN AMP
I just bought a custom fitted camaro box for 2 12"s subs for my 92 camaro Z28
My brother gave me 2 12" subs...they are Rockford Fosgates...my brother bought them new in 2001 and paid about $350 a piece...back then they were really good I guess...He only used them for about a year so they are in really good condition still
The problem is...he doesnt know much about subs or amp...and neither do I...here are some specs for the subs
Specs from: http://www.tuningmania.com.br/autoso...ord_f/subs.htm
RFR-1812 12" Punch Power Woofer (for each sub)
My question is What Watt power amp am I shooting for in RMS or MAX? or better yet...what amp...brand and model # would be the perfect match (or as close as possible) for those subs....also the size wire I would need depending on the amp you recommend
Also a question....how good are those subs (oldschool) rockford fosgate compared to the the new series like the P1,P2 or P3?? (in case I want to upgrade later)...
- Nominal Impedance: 8 Ohm
- Power Handling: 600 Watts RMS
- Peak Power: 1200 Watts
- Sensitivity: 88dB
- FS: 27 Hz
- QTS: .44
- VAS: 3.5 cu. ft. (99.4L)
- XMAX: 0.24"
- Voice Coil Diameter: 4"
- Mounting Depth: 5 19/32" (142.1mm)
Car: 1987 Trans am (SOLD), 1986 Trans Am
Axle/Gears: Stock
Re: HELP ME PICK AN AMP
An 8 ohm woofer is less "aggressive" than a 4 or 2 ohm sub. That doesnt necessarily mean it wont be as loud,but generally speaking the bass will be less boomy.(more accurate)
Most home theater speakers are 8 ohm,because in your home you can direct the speakers to your listening position,but not so in the car, thats why most car speakers are 4 and 2 ohm.
You should always look at RMS,Peak power is just the MOST power a speaker can take,like in a really deep bass note for example.
Speakers are more often blown by overpowering than underpowering, so make sure u always give ur speaks some extra room to breath.
600w RMS is a lot though....so you should be good with those subs,If u match em with a proper amp they will rock your socks off
Axle/Gears: Stock
Car: SOLD!!!!!
http://akamaipix.crutchfield.com/ca/..._8-ohm_2ch.jpg
just get a name brand amp. i have been using autotek amps for years of trouble free service.
Axle/Gears: Stock
Dont get brands like pyle,power acoustik,lanzar,audiopipe,sony,pyramid...I cant think of more right now....feel free to ask here before you buy.
[MN] S&W 8 point rollcage
FueledSoul
09-30-2015 09:18 PM
raymondandretti
09-27-2015 06:43 PM
FueledSoul
09-26-2015 12:00 PM
