Rockford Fosgate Question
Car: 1984 Berlinetta,'82 and '86 Camaro
Engine: Rebuilt 350
Transmission: Automatic. =[
Axle/Gears: Stock
I'm looking into a pair of Rockford Fosgate Punch P3 12" subs... I'm trying to figure out the right amp to run them... I'm trying to stay with the same brand but will look into other kinds...
Just looking for informational opinions or ideas.... thanks!
Car: 1986 I-ROC
Engine: TPI 305
Transmission: STOCK
Axle/Gears: STOCK
Re: Rockford Fosgate Question
i had 2 12" p3 subs in my 90 RS and ran them with a kicker dx 700 and got 180db out of them fosgate makessome good stuff but i think they fall behind in the amp area jmo
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
the world champion in db is getting 181.
u might might, be getting 130 t0 140
Car: 1986 I-ROC
Engine: TPI 305
Transmission: STOCK
Axle/Gears: STOCK
ok well thanks for being a *** but the db meter that was used read 180 i am going by what i saw
Car: 1989 gta
Engine: L98 D1SC procharger twin IC
Car: 90 Camaro RS
Engine: V6 3.1 MFI
Transmission: 4 Speed Auto 700R4
I would recommend posting this on crutchfield car audio forums they are really fast and friendly...and also know a lot about amps.
Good Luck!!
Car: 1988 Firebird - 1998 Z28
Engine: 2.8 - LS1
Ya... 180 isn't exactly accurate.. no offense to you personally. But that meter has to be off...
Car: 1987 iroc
Engine: blown up for now
Axle/Gears: 10 bolt/stock
are they 4 ohm x2 or 2 ohm x 2? either way, get something like this: http://cgi.ebay.com/PUNCH-200-DSM-AM...rQ5fAmplifiers
these old amps rocked. good, real power, and clean........ cheap too.
Engine: Rebuilt 350
Axle/Gears: Stock
now the 700 watts? does each sub get 700? or do they each get 350?
Well I know I'm new to this forum but I know my car audio. If you really want something to make those P3's slam, look into an old school
PPI PC2150. You can find them on ebay only, well maybe craigslist. You'll spend between $150-$200 but that amp rocks!! There's some other great amps for that price on ebay. But if you want to stay with Rockford I'd at least go with the T500 bd.
Axle/Gears: M78 9 Bolt Borg Warner
Phoenix Gold Amps are the best on powering Rockfard Subs and never overheat and put out super clean power!!!!! Phoenix Gold is on high price end but they last!!!
Car: 92 RS 98 SS 92 TY 09 CTS4 03 Yukon
Engine: L03 soon to be LQ4
Transmission: 700R4 soon to be 4L60E
I have 2 P3 10s on a punch 200 dsm and they punch pretty hard.
Not true, I have had several fixed, Rockford has a set price for fixing them or I got a stereo shop to fix one too.
Car: 1987 IROC-Z
With the P3s you can run the p500-1 amp or if i remember correctly the guy at the audio store said you could run the p300-1 amp as well. I have the p300-1 and its rms is 300 but max is like 1200 something or a little less.
Car: 1983 Camaro Sport Coupe
Engine: 2.8L, hopefully upgrading..
Transmission: BorgWarner T5, Made here in Muncie
Axle/Gears: stock
Okay, Assuming you are looking at the 08 model p3's (the ones with dual voice coils) then each sub is rated at 500 watts RMS (Not max) so to run these subs to the Rockford Spec you would need a 1000 watt RMS amp. Now depending on the voice coil configuration, depending on whether it is dual 4 ohm coils or dual 2 ohm coils matters. If you get the dual 4 ohm coils you can wire the subs to get a final 1 ohm load, which if you are looking at a new fosgate amp, they do their rated power at 1 ohm. The Rockford P1000-1bd is an excellent choice for the dual 4 ohm VC setup. The amp will do 1000 watts RMS at 1 ohm and a little extra if you have a good electrical setup. Now, there are other amps out there that would save you a bit of money. Buying the p1000-1bd with warranty will cost you over $400 usually. Yes i know you can get them on ebay for $200 but that is with no warranty from Rockford, so if you fry your amp your out of luck. But a good budget priced amp that would pair well with the p3s is the AudioQue 1200d. This runs about $220 brand new with warranty and is a solid amp.
Any more questions feel free to email me at Mikesmith0890@yahoo.com
and to the gentleman that said he was hitting 180 on a DB meter. This is not an accurate reading. The decibel level is measured using what is called a TermLab (or TL). This is what all audio competitions use to measure the sound pressure level (SPL). This is also the unit that NASA uses to measure the SPL of space shuttle launches. It is the only true method of measuring SPL. Also if you were to listen to 180db's for daily listening, you would most likely have been deaf a long time ago. Find a local car audio competition and demo someones vehicle that does 145-150 dbs and see if you can stand that. (the 145-150 range is very loud and a respectable number for SPL competitions.
Axle/Gears: stock
my .02
