Mold on subbox and no wetness??
Car: 87 Camaro IROC, 85 IROC Roadste
Engine: 5.7 V8 350 TPI, 383 - Coming Soon
Transmission: 700R4, Turbo 350
So I took my sub box out today because my subs have been cutting in and out but I think the Rem wire is loose somewhere or hitting another wire. But anyway, there was a TON of mold on the bottom right corner of the box and it has made the corner of the box bulge up and I dont know if it will be ok to put the box back in and use it or should I make a new box? All of the carpet is dry and as far as I know, there arent any leaks in the rear hatch, only my t-tops. Which I know the little bit of water that leaks there doesnt get all the way to the back of the car under the box.
Car: 1984 Berlinetta,'82 and '86 Camaro
Engine: Rebuilt 350
Transmission: Automatic. =[
Axle/Gears: Stock
Re: Mold on subbox and no wetness??
Deffinately replace those peices of mdf... MDF is like a sponge... any moisture there and it will suck it right up... after all... it is pretty much sawdust...
I have taken out the carpet around that whole area and there isnt any rust spots or holes. I know the seals dont leak in the rear so I dont know where the moisture would be coming from, other than the one little drain hole thats in the spare tire area.
Engine: Rebuilt 350
Axle/Gears: Stock
hm.. I'm stumped... was there someone in your car, or who has access to your car and could have spilled something and was scared to tell you? Only thing i can really think of...
Car: 1987 Trans Am
Engine: LQ9/L92
MDF is very absorbent; I found my 3/4" box was closer to 1 1/2" when I had a leak in my hatch area. It may not be very noticeable, but you can't have water back there without some kind of leak. Try putting a little bit of baby powder or flour on the side plastics and give the car a good washing. You should be able to find trickle tracks, no matter how small. I found that there's a little square section towards the back of the hatch near the sides that can have issues with sealing.
As for the box, you may be able to let it dry a bit more and hit it with a couple of layer of fiberglass to add some structure. However, if its wet, it will cause mold, possibly even inside the box.
Alright I will give those ideas a try. Thanks for the replies.
1Aauto
Sponsored Vendors
24
03-27-2018 11:59 AM
1Aauto
Sponsored Vendors
11-09-2015 02:25 PM
