Subwoofer Box with T-Tops.
Car: 1992 RS Camaro
Engine: Crate 350, XE CompCam
Transmission: WC T5
Axle/Gears: 4 Wheel Disc, 3.42 Gears
I know that I've seen a few pics of people running subs with T-Tops, but, anybody want to post a couple pics of what you have done with your subs/amps if you have T-Tops?
I'm thinking about having them set a bit deeper in the rear pocket so that the tops don't get in the way.
OR! possibly having them fire at each other down in the pocket leaving space for groceries, etc. in the middle aka two separate boxes or joined by a piece of wood that would also act like a support from the bottom.
Any suggestions?
Any suggestions?
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: Subwoofer Box with T-Tops.
Check out the build I had done for my 92 RS. Single 12" woofer with amp to power entire system.
https://www.thirdgen.org/forums/car-...amp-build.html
1 Post
Car: 90 z28
Engine: 355 with hsr
Transmission: t56
Axle/Gears: 3.73 posi
i put my t tops in the rear seat. if i have company they don't get to ride with the t tops down
Car: 1987 IROC-Z
Engine: Custom 383
Transmission: Tuned 700R4
Axle/Gears: 3.23 Posi
I built a baffle board that sits in the rear well on the two ledges on either side. When you put the T-tops in, just lay them on the part closest to the rear seats and strap them in, and everything is fine.
Car: 1991 Z28
set up looks good i need to do something like that
