Help with rear speaker installation
Car: 1988 Iroc-z Camaro
Engine: 305 5.0L V8 TBI
I dont care for hooking up amps and bass systems I just want something better than stock speakers. I own an 88 Iroc-z and apon looking up the size specification it looks as though the rear back side speakers are 6x9 but are only a 2 inch depth. Apon looking at any aftermarket speaker there is no 2" depth allowance all of them have 2.5-3.75" depths. Has anyone encountered this issue or have any advice as far as what to do regarding this?
Re: Help with rear speaker installation
Welcome to TGO. Try http://www.crutchfield.com/ From the website you should be able to determine what will fit.
JamesC
JamesC
JamesC
JamesC
JamesC
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
the crutchfield info must be wrong-factory 6x9s are
2 1/2"behind the frame flange,and i have some
"old skool"mid-'80s rockford fosgate 6x9s in my car
that are about 3 1/2"behind and they fit with about
1/2"clearance. many thirds though have an enclosure
made(as i remember)of soft fiberglass behind the 6x9s
(my '82 didn't have these),that might limit avalible
depth some,could remove or modify these. Biggest
clearance problem i had with aftermarket 6x9s
is the outer plastic ring that surronds the front of
the speakers can only be about 3/8" thick or the
factory cover will not fit-had to trim some down to
fit,tweeters can stick out about 1/2" above.
I have an '88 with the fiberglass boxes. Just put in some Memphis PR 6x9 3-ways. 3" mounting depth. Fit just barely against the back. I would not go any deeper than 3".
hectre13
12-11-2023 08:14 AM
db057
08-11-2015 10:11 PM
