Whats the best speaker application for the sail panel?
Is a 6X9 or a 6" component system better for the sail panel area?
1 Post
Car: 1991 Camaro Z28 Clone
Engine: 350 w/TBI
Transmission: WC T-5
Axle/Gears: Spicer 3:73 Auburn Posi
Re: Whats the best speaker application for the sail panel?
I never liked the sound a 6x9 gave. It was a design to try to get the most out of the size.
If you plan on upgrading to aftermarket especially with an amp and a sub, go with the component setup.
Metra makes a awesome 6x9 adapter plate that mounts right where the factory 6x9 mounts and allows for a 5 1/4" or 6 1/2" Speaker to mount in its place.
http://www.cartoys.com/Default.cfm/p...9_5_25_OR_6_5/
I have them in my car with Polk Momo 5 1/4" Speakers.
Much Much better...
Much Much better...
Much Much better...
Much Much better...
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
I use abs plastic and I draw out the template and then cut it out. I have a set of 6.5 components and 3.5 concert tweets in the sails on mine and I have plenty of room for more. As long as you shim the plates to angle the speakers in your direction a little they will sound alot better.
Car: 1987 Trans Am
Engine: LQ9/L92
In my first go round with these cars (84 Camaro), I kept it simple by just throwing in a 6x9, but there's a much better selection of 6 1/2" out there for less money. My second try (89 RS) I cut some MDF baffles in bolt them in place of the "enclosures" that were there. Spent half the money this time and much happier with the outcome.
formula00ra
Interior Parts Wanted
09-28-2015 11:50 AM
