My New System. What do you guys think?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 92 RS
Engine: 305 TBI
Transmission: AUTO
I cant wait to get this stuff in my 92 camaro.
Headunit
kenwood kdc x792 $200
MA Audio 6x9's $100
Front speakers
Kenwood KFC-4675C 4"x6" $50
http://cgi.ebay.com/ws/eBayISAPI.dll...m=200302342107
Door Speakers
Kenwood KFC-1382IE 5 1/4" 160W $43.00
http://cgi.ebay.com/ws/eBayISAPI.dll...m=190281556724
Amp for Front, Door, and 6x9's
Rockford Fosgate 4 channel 900 Watt Amp $105
http://cgi.ebay.com/ws/eBayISAPI.dll...m=260360893374
Sub
ORION 15" HCCA SUBWOOFER $225 With shipping
http://cgi.ebay.com/ws/eBayISAPI.dll...m=220358631852
Amp for Sub
Orion HCCA-D2400 2400W Class D Mono Amplifier $180
http://cgi.ebay.com/ws/eBayISAPI.dll...m=270343925029
MONSTER CABLE CAR RCA $30
http://cgi.ebay.com/ws/eBayISAPI.dll...m=220348642235
ROCKFORD FOSGATE GROUND DISTRIBUTION BLOCK $15
Tsunami 4/8 Gauge Digital 4 Pos AGU Distribution Block $17
http://cgi.ebay.com/ws/eBayISAPI.dll...m=350165395888
Ive also got 4 gauge power wire to the distribution box.
From distro box. ive got 8 gauge positive and negative wire to the amps.
Also went out and got 16 gauge speaker wire.
So what do you guys think. I hope it sounds good. lol
Headunit
MA Audio 6x9's $100
Front speakers
Door Speakers
Sub
Amp for Sub
Car: 1989 Camaro RS
Engine: 355 lt1
Transmission: 700R4 stage 2
Axle/Gears: 3.73 gears and a 9 bolt borg warner
Re: My New System. What do you guys think?
not bad it sounds like a nice set up heres a link to mine
https://www.thirdgen.org/forums/auto...ut-custom.html
Car: 92 RS
Engine: 305 TBI
Transmission: AUTO
got a quick question. im running 4 gauge power wire. What size fuses should i get for the amps?
Car: 1983 Camaro Z28
Engine: 305, holley 4bbl. stock for now
Transmission: th200c, 700r4 coming in spring
4ga is not thick enough for that sub amp. you need 1/0ga to your distro block. then 4ga out of there to your amps. you really need a capacitor, and a second battery to be running that sub amp too, but you might get by for awhile.
4ga is fine for your mid/high amp.
as far as fuses. i dont really know the answer to that. hahaha
an 80 should suffice for your sub amp, you need at least one cap for the sub amp, possibly one for the 4ch. Definately another battery, a 140amp alt, and a #0 wire to the dist block, possible a #2, and at LEAST 4g to the sub amp, and at LEAST 4g to the 4ch. sub amp probably will want #0
Car: 1983 Camaro Sport Coupe
Engine: 2.8L, hopefully upgrading..
Transmission: BorgWarner T5, Made here in Muncie
Axle/Gears: stock
4 gauge is fine for you power wire. That orion amp puts out no where near 2400 watts. As well as the RF does not put out 900 watts. The claims on both of these amps are false. The rockford 301x puts out approx 350watts rms bridged. and about 40x4 per channel @ 4 ohms. You'll never see 900 watts out of it.
The orion since you are only running 1 sub rated at 600 watts rms, you'll most likely leave it set to pull (2 ohms since thats the configuration of the voice coils) of power from the amp which puts out 800 at 4 ohms, 800 would most likely be too much on the Orion sub. 800 watts can be done right, but many subs can only see a little more than their rated power while others can take almost twice the amount.
To summarize, if you run the sub @2 ohms then you will be fine running 4 gauge wire. Just be easy on the gains and bass boost, otherwise you can run the chance of overpowering your sub.
On the otherhand.. pick up another sub, upgrade to 1/0 and run at 1200 watts @ 1 ohm, you'll be happier and get your moneys worth
Hope this helps
Hope this helps
