Back to stock Stereo installation Need Help
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
I purchased a stock Delco stereo for my 84 Camaro from EBAY. It had a 3.5 jack installed on the amp. When I went to install it I found that on my console there is an installation bracket to the back where I suppose the screw on the back of the unit goes. Then on the unit itself there are two bolts, one on each side, but no bracket on the console. On the front of my console there are four bolt holes where I think my old unit must have attached, but no place on the new unit to thread into. Clear as mud?
What are my options? Is there a bracket I can get? or do I have to get the correct console for the new unit? My aftermarket stereo used a faceplate that fit the four front facing bolt holes but it stuck out a few inches and there's no way that faceplate will slide over the new unit. Believe it or not, I like the look of the stock unit and it works with the restoration of my car.
Any suggestions?
Any suggestions?
db057
08-11-2015 10:11 PM
