Xm in 3rd gen Convertible
Newbe here... Bought my first 3rd gen , just bought a 91 TA convertible , I changed out the old radio and put in a delco from a 4th gen. Plugged right up. Wanted the stock look.
Now i am going to use the 9 pin plug [unused] to my XM Radio. Bought a GM5-gm9 so i can hard wire the XM to the radio. All this was easy.
The hard part........ Were to put the XM antenna in a Convertible ?
Anybody ever done this?
Car: 91 RS
Engine: 350 TBI
Transmission: World Class T-5
Axle/Gears: 3.27 9-Bolt LSD
Re: Xm in 3rd gen Convertible
my 91 has a cover over the dash (cause its just flat nasty lookin) so i cut out some of the cracked up nasty dash and my sirius ant gets perfect reception and on 95 plus cavaliers you have to pull the whole dash off to put a radio in and i just put the ants under the dash and they always got service so id try that and post back im a little curious. worst case scenario just stick it in the corner of the windshield on the dash, i know thats garunteed to work.
Car: 86 Trans Am
Engine: 385 Fast Burn
Transmission: 700R4 - stock (eep!)
Axle/Gears: Stock, will upgrade at some point
Done that with my daily driver, throw the antenna up on the dash, works great. And with a convertable reception will be that much better.
Car: 91
Engine: 3.1 v-6
if you throw it up on the dash be sure to hide the wire.. but you could also put it back by the trunk on the outside..
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Where did you find the GM5-GM9 interface cable? All the ones I can find say you need to have the slave (cassette or CD) intalled and turned on in order for satellite/aux to work.
I got the gm5-gm9 from installer.com. They didn't have it it stock, BUT found it from some other place. Told me that didn't make it anymore, but called somebody to get it. 3 days later it was here $75.
I have the new express RC XM radio. It's a 5 volt radio. then the 9 pin to go in the delco radio. My delco is a 01 monsoon and i think you have to have a 2000 or later delco with the 9 pin in the back for this to work.
Not All XM radios are the same volt, my roadeyll is 6 volt.
It sure makes for a clean install doing it this way.
Car: Camaro RS
Engine: 305 TBI
Axle/Gears: 3.45
place it inside the car next to the rear veiw mirrior or some where near the top of the windshield inside to car
By the way I have sirius xm sucks
Car: 86 Trans Am
Car: 1984 z28 camaro / 2019 accord sport
will they be double broadcasting because i love my inno and it would be sweet if i could get a few sirius channels
Car: 86 Trans Am
From what I hear the current radios won't cross over to pick up the others, that's in the future. Haven't heard much about how they are going about setting up the technology or if they are doubling it up but I'm assuming the current satellites don't have the right programming/tuning to double up. Hell the Grateful Dead channel is still listed as "Sirius Disorder" lol
Car: 1988 GTA Black notchback
Engine: 1991 L98 355 TWIN Superchagred
Transmission: 700r4 shift kit 2500 stall
Axle/Gears: www.cardomain.com/id/gtafanatic
welcome to 3rd gen
when you get a chance post up some pic on what you decided to do
