corvette head unit
Car: 91 Camaro RS
Engine: 3.1L MFI
Transmission: Hydra-Matic 4L60
corvette head unit
does anyone know if I need to get a special harness for the head unit to install my amp and subs?...i have a 2004 corvette head unit in my car and i dont want to buy another head unit if i dont have to...
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: corvette head unit
You need a line level converter to change your speaker level outputs to preamp RCA type outputs to connect to your amp. Almost any car audio store will carry these. The can induce noise into your system if you get a cheap one. One of the best is made by Peripheral like this piece http://peripheralelectronics.com/pro...trSearch=sven2, but it's a bit spendy.
I might go that route in my 89 RS. I have the same radio but it came out of a 2002 Chevy/GMC truck.
Car: 91 Camaro RS
Engine: 3.1L MFI
and does this just plug into the back of the head unit and then into the amp?
Sort of. All you want to do is add some subs and an amp and keep everything else as is right? Then all you need is a two channel version of the piece in the link. You need to splice into the speaker wires from the back of the head unit (the rear channel would be ideal), that way you can still use the speakers as is. Run the new leads (the ones you tapped off the speaker wire) to the converter, then run a set of RCA cables from the converter to the amp. This diagram holds true for some less expensive line level converters also, you can splice either at the speaker (shown) or at the head unit (easier).
http://peripheralelectronics.com/per...ions/SVENR.pdf
ambainb
04-25-2016 09:21 PM
