single sub box?
Car: 1986 z28 <sold>
Engine: iron head 383
Transmission: th350
Axle/Gears: 4th gen 3.23 posi
single sub box?
does anyone make a hatch style sub boc that only holds 1 sub and is half that size so u would still have half ur well ???
1 Post
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
Re: single sub box?
that's something that would need to be custom manufactured. if you did have one made, you would need to make sure that it wouldn't slide around in there.
Re: single sub box?
Infinity makes a pretty decent amplified one. Look for it on Crutchfield and then find it cheaper somewhere else. Its pretty neat and sounds nothing short of damned decent.
You could also have a bass tube back there and keep 1/2 of your vertical space. Here is my setup
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: single sub box?
Unfortunately no one makes a single box for the 3rd gen. You will have to have one custom made....or make one yourself to match the specs of the sub.
Car: 87 GTA
Re: single sub box?
You could always consider getting a pre-made box for 2 10"s or 12", cut it in half, and put on a new wall.
Do the same to the other side, and sell that one off. I'd do that, but I have a Bazooka tube (granted, it's not the best, and can sound a bit muddy, but it came with the car), so I'm not going to go buy a new speaker & an amp.
Transmission: th350
Re: single sub box?
t2152d4 i like that thats kinda what i was thinkin wat size sub is that im also thinkin about puttin a single ported box in the hatch ...any 1 think i would still be able so see out the rear view?
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
Re: single sub box?
this is the one i made for my single type-r. i wanted to only use the bottom half of the well so that i could cover everything if i wanted to and also be able to use the stock t-top bag. took a few tries to get everything to fit right, but this box fit almost perfect and had just enough airspace for sub. too bad it got ruined because the hatch was leaking
Car: 2007 Cobalt LT
Engine: M62'd 2.2L L61
Transmission: 4T45E 4-speed Automatic
Axle/Gears: Stock
Re: single sub box?
If you're building a sub box, you have to know exactly how to do it. If you make the box wrong, the sub can actually sound horrible. I have an MTX 10" Sub, that came with the box, and it fits right in the corner of the "storage" area, and just faces the left side. Sounds just fine, though I might end up moving it to face up.
[Sold] Flowmaster exhaust system
Night rider327
10-09-2015 09:25 AM
Dragonsys
09-25-2015 03:51 PM
