need single 15" sub box plan!!!
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Transmission: 700R4,700R4
Axle/Gears: LSD,LSD
i want it behind the seats..in the hatch..ported too..if anybody has somethin like that or can come up with somethin pleaaaase let me know thanks
Car: 72 Fbird. Want another 3rd gen :(
Engine: Poncho 350
Transmission: Turbo 350
for your l7? or l5? how much airspace does it need? cause im gonna need some plans for a 15 too.. for around 3-4 cu. ft. ported if thats possible
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I'm doing mine in the well, out of fiberglass. 15" L7. It'll be around 4-4.2 cubic feet, and then adding ports. You *need* ports for a solobaric.
You're better off just starting fiberglassing, then building it up a bit higher than the top (above the gas tank), maybe 4" or so, then using the stretchy fleece to cover the top. Make sure the sub is high enough that it doesn't hit the well, or the window (it's close). Then glass it all up and build up the top thickness more. I think 3" PVC tubing about 18" long, dual, would work ok for ports. I think i'll use polyfil personally.
Engine: Poncho 350
sonix PLEASE make athread about yours or seomthing and keep it updated.. im gonna be going with either a 15" Fi SSD or 15" RE SX and need a box around 4 cu. ft. ported
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Axle/Gears: LSD,LSD
yeah its for my L7..i think its pretty sick and id like to keep it..i really dont wanna glass anything..never done it before.. and ya as much cubic feet as possible is good
Engine: Poncho 350
yeah no glassing for me.. but i decided on a Soundsplinter RL-p 15" .. but whoever has pics of a 15" setup post them please :]
Engine: Poncho 350
Re: need single 15" sub box plan!!!
lool hey there maroon :] nice chrome irocs.. 17 or 18? j/k im ElBandito on caraudio.com :P
Hotrodboba400
12-10-2019 07:07 PM
