Beefing Up The Sail Panel Enclosures
Car: 87' GTA
Engine: 350 L98 TPI
Transmission: 700-R4
Axle/Gears: 3.27 9-Bolt
Alright, since there's a little room for improvement when it comes to getting better sound out of your 6x9's, why not do it.
My question is since the "Enclosures" are made of some sort of insulation material, what other ways are there to make them sturdier, WITHOUT fiberglassing them?
I was thinking of covering up those holes with something and then spraying it with multiple coats of rubber undercoating? I think enough coats of the stuff would work.
Two more questions, WHAT would I cover those holes with? and How do i remove the metal plates that the speakers are screwed into?
Car: 89 RS Camaro, Metallic Blue
Engine: 2.8 V6 (The 350's comin)
The metal plates are held in with screws. I sprayed mine with a few coats of rubberized undercoating as well, you will be happy with the difference. I also replaced the metal plate with a plate made of 3/4" MDF and it made a difference.
Car: 1991 RS
Car: 2000 Trans Am WS6 (Black)
the biggest deal is NOT where the 6x9 mounts, it's the outer skin on the car, and all the plastic panels that the 6x9 can vibrate.
your best bet is to seal off the 6x9 compartment, while leaving it as large as you possibly can...
most people just toss in some cheap-o 10" sub or something, because it will be cheaper and easier...
formula00ra
Interior Parts Wanted
09-28-2015 11:50 AM
