dynamat?
Car: Trans Am
Engine: L69
dynamat?
for those of you who put dynamat in their cars, about how much do I need to buy??? Thanks
Car: 1986 Trans Am/1993 Trans Am
Engine: 305 .030 over built/ LT1 Bolt Ons
Transmission: t5/700r4
Axle/Gears: 3.43 Posi/3.23 Posi
Dynamat isnt the best anymore, and its expensive. How much do you need? heres some thats cheap and works great!
Cascade Audio small pack
Cascade Audio Medium pack
Cascade Audio Medium Pack
Cascade Audio Large Pack
Cascade Audio Large Pack High Dampening
COTM Editor
Wish I had known about that stuff! Dynamat is retarded heavy and exspensive.
Car: '85 TA
Engine: Aluminum Fuelie
Transmission: Mother of All Manuals
Do a search for Second Skin on these forums. I would recommend that if you're looking for something equal or better (IMO) than Dynamat Extreme, or buy RAAMmat for more a more affordable mat. I've used both RAAMmat and Damplifier in our cars, and they work great. 120sq feet will do the job if you're planning on doing a double layer on the firewall and wheel wells. And this link is a highly recommended read if you are shopping for sound deadener.
Car: TWO 1992 CAMAROS 1 Z28 AND 1 B4C
Engine: 1 LQ9 AND 1 LS3
Transmission: 1 T-56 AND 1 6L90
Axle/Gears: 1 4.11 AND 1 3.31 (DANA 44)
Dynamat is the best....
As far as how much you need.... It all depends on your car and your budget....
Dynaplate weigh almost nothing.... But it will cost you....
Car: 1990 Formula
Engine: 383 Stroker
To answer the original question about "how much to buy", that also depends on which product you use. For Dynamat Xtreme or a product with similar damping properties, 36 sq. ft. would do a good basic installation. It would cover the inner door skins and the front section of the floorboard. These areas are the most effective in reducing road noise and vibration. Another 36 sq. ft. would cover the hatch floor and sides. With (2) boxes of 36 sq. ft., you would have enough to do the outer door skins as well. Another benefit with using a high quality product is that the areas do not absolutely have to be covered to be effective. I have found that anything above 50% coverage will do a good job. 75% coverage will do an awesome job. HOWEVER, using a cheaper product may require a more complete coverage and possibly more than one layer to achieve the same results. I would not worry about the roof. In the vehicles that I have applied it to the roof, I have not noticed a significant benefit (unless it was a SPL competition vehicle).
Here's a link to the Dynamat website. There is a ton of info and technical applications available.
The Official Dynamat Website
gixxer92
04-12-2022 12:09 AM
