4th Gen Delco CD Player Installed
Car: 91 Camaro RS, 99 Camaro Z28
Engine: L03, LS1
Transmission: 700R4, T56
Axle/Gears: bunch of 10 bolts how scary is that
I know this has probaly been done 400 times but I figured id post pics. Install is easy the stock harness plugs right into it just like the stock one. Only thing I have to do was remove the stock metal bracket inside the hole for the radio it was in the way
Brackets fit perfectly and no gaps or anything.
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Looks great! does that one come with the speed sensitive volume control? My girlfriend's cavalier has that, very cool.
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Originally Posted by BT283
what the hell is speed sensitive volume control?
I wish the aftermarket would get this feature. But it is built into the GM radios.
Car: 1991 Camaro
Engine: 5.0L
Transmission: A4
I could care less about the SCV , I just want a Stock GM CD player , they look better and sound OK for what I need .
Mark
Engine: L03, LS1
Some having different mount styles. I got mine out of a S10 kris will tell you what year.
Car: 1992 RS
Engine: 3.1
Welcome to the club! Almost every Monsoon CD player out of a later model GM truck or camaro will work. Corvette's are different and will not work. You may need to fab up a bracket. I got mine out of a 2000 SS. The only modification I had to do was to cut a little bit of the heater duct out, but that was no problem at all. Other than that, it bolted right it. Next is to do the SCV.
[IMG][/IMG]
[IMG][/IMG]
Car: 1991 Camaro
Engine: 5.0L
Transmission: A4
[IMG][/IMG]
[IMG][/IMG]
Thanks again , Mark
Car: 1992 RS
Engine: 3.1
I've been in thirdgens for over 10 years and I have yet to feel anything come out of those vents. So I just sealed it with foam that way laying around.
My dad recently put a CD/Cassette player from an Olds in his Iroc. I fit with about 15 mins or pursueding. Half of the bottom buttons are covered up by the radio bezel but you can still push them. I'll try to get a pic of them tonight. We also needed a harness for it.
Car: 1991 Camaro
Engine: 5.0L
Transmission: A4
Car: 1992 RS
Engine: 3.1
It doesn't fit as well as the others because it's not a 1.5 DIN like the stock players and the Monsoon.
It is a VERY tight fit, but all we had to do was bend the metal bracket for the climate controls up a little bit and persuede it in. I think it looks pretty good. Plus it's a CD/Cassette player.
Car: 1989 Camaro Iroc-Z
Axle/Gears: 2.77 Posi
I love the 4th gen CD player install, really clean and better than an aftermarket IMO, i have an aftermarket in mine down since i have amps, subs, etc but when I yank those out, im definatly doing a 4th gen CD deck swap. Nice job
Side mount, the radio out of my 2002 S-10 went right into crrllmich's 91 RS using the mounts already on the radio. Ask with the details of the install. A 2001 S-10 is the exact same radio as the 2002 If anyone does decide to do this, I strongly suggest hooking up the speed sensitive volume. It's not hard to do and it's so cool.
Car: 1992 RS
Engine: 3.1
Engine: L03, LS1
Yes.
I also want to note. This does sound on par with aftermarket radios.
I will soon be putting infinity reference speakers in the side panels, dash, and rear bose gold assembly. I will let you guys know how it sounds.
Car: 1991 Camaro
Engine: 5.0L
Transmission: A4
Hey Guys : I picked up a 94 delco cd player for $30 !!!, all the lights work and is in mint condition.
( stock style cd player that was in my car originally )
It hooked right up and even plays burnt cd's !!
Pics coming soon !!
Thanks again for all the help fellas
Pics coming soon !!
Car: 1987 Camaro IROC-Z
Engine: LB9
looks familiar
i had to make an adaptor to use the new style harnas on my 87' and i can't use the SCV since i have a cable speedo.
got mine out of a 97' cavalier, had to replace all the lights in it, but i love it.
Engine: L03, LS1
Just got mention I didn;'t have to change the harness...bolted right in.
I am also working on installing a Delco 12 Disc CD changer as well.
OK, I'm new to third generations and need some clarification. I have just aquired an 87 GTA with no radio and would like to install a later cd type factory in it. What do I need to put something like the monsoon in this car?
Phil
Phil
Car: 89 Iroc Convertible
I installed a delco CD Player in my 86 Iroc.This was pulled from a 1993 Buick Roadmaster Wagon.
Car: 1991 Camaro
Engine: 5.0L
Transmission: A4
Car: 1991 Camaro
Engine: 5.0L
Transmission: A4
Phil: The Monsoon will NOT work because your harness does not have enough wires in it, with that said , can it modified......?? not sure.
I know that the Non-monsoon type cd players will fit right in as noted in previous posts above without any mods to your harness (provided it has not been tamperd with)
If you read the previous posts ( like White93Z's ) that type will work.
Hope that helps.
Mark
1992rs/ss
05-19-2020 07:02 PM
1992rs/ss
16
01-28-2016 09:58 PM
sailtexas186548
01-19-2016 12:21 PM
