looking for alittle more loudness
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
I dont listen to rap or hip hop so i dont want subs caz i dont like that much bass in my rock. But i do want a little bit more out of my audio. I have 6x9 300w 3 way pioneers in the rear and 12w 3 way pioneers in the front and a 50wx4 mosfet pioneer head unit i kno pioneer isnt the best but i figured a amp will solve what im looking for i want louder and better sounding will a amp do this for me? Should i get a 2 channel, 4 channel, mono amp? I dont kno much about audio just under the hood is were i kno my stuff so help me out what is the difference in 2 channel, 4 channel, and mono btw?
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
the difference in channels is how many speakers you can run on that amp independantly.. ie 2channel = left chanel and right
4channel = Left Front Right front, lft rear right rear
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
Amp
Im looking for louder sound but i dont want it to sound like ****. So basically i should get a 4 channel so all four speakers get more watts?
Car: '85 TA
Engine: Aluminum Fuelie
Transmission: Mother of All Manuals
Louder? Good night man, toss some sound deadener in there to dampen the outside noise. No sense in losing your hearing just to listen to music.
As for quality loud sound, you need some good speakers (not sure what models your Pioneers are) and a good 4 channel amp. Head units make a difference in sound quality as well.
2 channel amp: 2 channels... can drive two speakers or one when bridged (on certain amps)
4 channel amp: 4 channels, same idea as above
Mono amp: used for subs, single channel
Car: 1991 Camaro RS
Engine: 357cid
you will need better speakers, and IMO i don't prefer Pioneer for their speakers....
I suggest MB quart, Infinity, etc..... also a good H/U if you odnt have one
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
should i use this amp?
heres the amp i found
Buy the Pioneer 4-Channel Amplifier (GM6200F) and other Car Amplifiers at circuitcity.com
Anybody got a link for some 4x6 and 6x9 speakers that can handle this amp? The speakers i have in the front are pioneer 120w 3 way and in the rear i have 300w 3 way 6x9's. Can the speakers i have handle this amp? Also the pionner head unit i have has mosfet 50w x 4.
Car: 89 iroc-z
Engine: 305 tpi
Transmission: auto
Axle/Gears: stock
I was in your shoes last year and I did exactly what most are saying. 4 channel amp is the way to go. my JL 4300e was pricy but is an awsome amp and the quality difference from my alpine head unit was amazing. Ive got alpine type S speakers all around and although not top of the line, I will never replace em. A good amp and speakers will beat any 1000$ bose systems you find in Cadilacs ( I work on em, i know).
Also, whats great about a 4 channel is that if u ever decide you want to try on a little bass (even a small sub will make a world of difference), you can simply bridge 2 of 4 channels and have both amplified speakers and a subwoofer. I listen to rock music too, and bass will send chills own your spine when your playing your favorite songs.
If you want crisp clear and loud, buy a GOOD amp, dont get a 150-200$ amp. If your gonna get one, pay a litte more and youll never regret it. If you absolutely want pioneer, go with their premier series http://www.pioneerelectronics.com/pn...600357,00.html
Dont be fooled by Watt numbers. Compare Sony with Alpine watt for watt and its like comparing chocolate to poo.
Car: '85 TA
I don't know too much about Pioneer's amps, but it looks ok to me. Kenwood and US Acoustics are decent amps for the money. Alpine is better. You might also want to check out the Kenwood KAC-8402. Your speakers are 120W Max and 300W Max. You need to know the continuous rated power (RMS). Your Pioneer HU should be fine, but for an amp you'll want to make sure it has preamp outs (you don't connect your amp to the speaker line).
Car: 89 IROC-Z
Engine: 355 TPI
STOP looking at Pioneer amps, you can do much better. I love Pioneer HU, but there are much better for amps and speakers.
What kind of budget are you working with?
And what model# Pioneer HU do you have?
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
Profile amps are rather good and dirt cheap if you get them factory refurbished at their online store
Car: 1991 Camaro RS
Engine: 357cid
Choose new speakers first then choose an amp. At least that's what I do and it makes life a lot easier.
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
other post
my other post has the set up i wanna run what do you all think about that setup?
Car: '85 TA
No need to do a new post my friend.
Go to Crutchfield.com and see if the speakers fit your car. The Kappa's are nice, but you need to note that both sets of speakers are 2-ohm speakers, so you need an amp that does 2-ohm which the Punch does (100W x 4 @ 2 ohms). Your 4x6's are rated @ 60W (180W peak) while your 6x9's rate in at 110 RMS (330W max). I would say you might be ok with pumping 100W to your 4x6s, but I haven't tried it, so I'm not sure what they'd do after time. Maybe some of the others can chime in.
Well ive been searching all around for a nice setup up and heres what i came up with as for the head unit im gonna go with the alpine 9851, for the speakers i found some nice infinity kappa 4x6 462.7 and infinity kappa 6x9 693.7 for the rear. For a amp i found a rockford fosgate punch p4004 amp. Will all these parts work in my iroc and will that amp be good for the speakers i picked?
Car: 1989 Pontiac Firebird Formula 350
Just as a personal preference, I wouldn't go with the infinity Kappa's. I had a set of Kappa's one of my old cars and I ended up switching them out with a set of alpine speakers and the alpines sounded a lot better than the kappa's. They were being run off of an MTX 5400x at the time. I believe the alpines would be a little cheaper than the kappa's as well to save you a little money. This is just my perference on speakers so you dont have to go with them or not.
Car: 91 Firebird, (miss my 87 Formula)
Engine: LO3
I put a pioneer amp at the max rating of my pioneer 3 ways (same size as yours) in my old formula a few years back and I honestly didn't notice much of a difference except my 4x6 distorted from being over powered and I ended up blowing one. This was about 6 years ago though and the pioneer speakers have gotten a bit better since, but as most people have already said you should probably start looking at some better speakers and a better amp than pioneer if you want better sound. You get what you pay for is generally true with car audio, though there are some deals and ripoffs to be found.
Why not go with a single sub and keep the rest powered off the head unit? If you go with a decent single sub in a sealed box and a good amp you can always turn the bass down if its too much, and it will give you a much fuller sound.
1 Post
Car: 2001 SS
Engine: bolt on LS1
You should run a 8''s bazooka tube not too much bass in it but it deepens up the sound. My uncle has one he is 65yrs old and loves it. He got lucky and found it a shoping cart at the walmart parking lot.
Car: 1991 Camaro RS
Engine: 357cid
Engine: LO3
For the price of a bazooka tube you could get a much better sub/amp (try ebay or refurb sites) and build your own box or get a cheap premade for less than a bazooka tube. It would also sound 100 times better and you have the freedom then to tune it how you want.
luvofjah
09-26-2015 08:28 PM
