MTX 3002 amp. Good or bad???
Car: Camaro RS
Engine: 305 TBI
Axle/Gears: 3.45
All mtx amps are good amps and all of them are under rated rms wise. Also I believe they are the easiest amps to get fixed and probably the cheapest. I paid 125 for a broken mxa6001. Then paided mtx 85 to fix it best soundin bass ever.
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
Product Info for specs and what not. You can get it for $140 new so I would offer around $50-70 used.
IMHO I'm not sure what you would do with it. It's not exactly the beefiest amp out there but it would run a set of speakers fairly well or two sets if you wanted to bridge down to 2 ohms. Defiantly not an amp suited for sub duty.
Thanks guys for the advice. He had priced it at $75. Crutchfield has them listed at $199. Im sure there are cheaper on ebay.
I took my subs out for drag racing, so I dont really need it.
He ended up with a capacitor also. I dont know the specs on it, but Im sure he will want to sell it also.
Car: 88 GTA
Don't bother with the cap. It's not worth your time especially considering the power you're running. Upgrading your grounds (battery to chassis and chassis to engine) would be a much better use for your money.
