Kenwood KAC-929 cutting out
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
I've had this amp for 3 years now, and never had an issue. In fact, I bought another for my other car since I had no problems!
Well, the original one has a problem that developed about 2 months ago. After about 6 or so minutes of hard bass; the amp cuts out. It will come back after about 1 minute every time.
I thought it may be overheating, but I took the back off and there was nearly no dust/crud, and the fan is working fine.
Any ideas?
Any ideas?
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
Originally Posted by NEEDAZ
Do you have a DMM (mutimeter)? Do you know how to use it?
Car: 89 IROC-Z
Engine: 355 TPI
Set the DMM to read resistance. Put one meter lead on each of the terminals for one coil at a time. If there 4 ohm VCs you should see something like 3.5 ohms per coil. Post up what you get for each coil.
