Fitment Question
Car: '88 IROC-Z
Engine: StealthRammed 355
Fitment Question
I'm lookin to upgrade my factory Bose headunit to an aftermarket one and although I won't be buying from them, I have been browsing Crutchfield and some of the head units say "Will not Fit." But I have read on here that these same head units have been used before...is it because the head units won't work with the Bose system or somethin else?
Car: 88 camaro, black, T-tops
Engine: 305 5.0L
All depends on how creative you are. Basically a half din, which is standard, will fit right in with a mounting kit like a metra #99-4544. If you desire to fit a double din, you can with a bit of customization. But you will have to hack up your dash bezel to do so.
Our stereos are din and a half. The description doesn't do it justice since they are wider than the standard din size.
Car: 89 IROC-Z
Engine: 355 TPI
The standard is DIN. You'll need a dash mount kit and wire harness. The dash kit will make the HU stick out about 1.5". You can get some ABS sheets and make a flush mount if you like, but you'll need to cut the vents behind the radio, no big thing. I'm not to farmilyar with the Bose stuff but from what I remember your wire harness will be different then most because you have Bose. It's more like a harness/addaptor. Unless you just want to run new wires to the speaker and totally bypass all the Bose things. But if you do this you'll need to check the speakers. I think some of the Bose systems used real low resistance speakers, like 2 or 1 ohm. The new HU will not like that.
kah992
08-19-2015 02:55 PM
