help: mono amp running 2 subs
Car: 1984 pontiac trans am
Engine: Block #14010209...350...80-85
Transmission: 700 R4
ok im posting for a friend and im not exactly sure if this will work or not and do not want to give the wrong info.... he has a mono amp, and 2 12'' subs. i know he will have to run in parallel, and that (i think) they will be running at 2 ohms
amp: FP-402 (fusion)
CEA 2006 Compliant Amplifier Ratings
12.6 Volt Power Output Specifications
50 WRMS per Channel @ 4 Ohms and ¡Ü 1% THD+N
96 WRMS per Channel @ 2 Ohms and ¡Ü 1% THD+N
160 WRMS Bridged Channels @ 4 Ohms and ¡Ü 1% THD+N
66 WRMS per Channel @ 4 Ohms and ¡Ü 1% THD+N
100 WRMS per Channel @ 2 Ohms and ¡Ü 1% THD+N
200 WRMS Bridged Channels @ 4 Ohms and ¡Ü 1% THD+N
sub:FEW-12DVC (fusion)
Magnet Structure: 80 Oz
Power Handling (MAX): 400 Watts
Voice Coil: 2" Kapton SVC
Impedance: 4 Ohms per coil
Free Space Response (Fs): 27 Hz
Efficiency (1W/1M): 91dB
Frequency Response: 23Hz-3kHz
i guess my question is would the subs run at 100 rms per channel? and would that be underpowering the subs? or should it work ok?
Car: 88 firebird
Engine: 3.1
Transmission: Stock-auto
Well according to those specs, the sub is not mono, mono of course, means 1 channel, and you cannot bridge a mono amp, however the specs do show bridged output, so either it is a 2/multi channel amp or the specs are incorrect
Car: 88 firebird
Engine: 3.1
also, in the sub name, the last 3 leeters, stand for Dual-Voice-Coil, however in the sub specs, it says single voice coil, another mismatch, it would also help to include rms/continuous power instead of peak power handling.
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
The subs are 4 ohms (per) coil, so dual voice coils. The model number denotes a 2-channel amp. The subs in parallel would make the amp see a 2 ohm load in bridged mode, however the amp is only rated at a 4 ohm load bridged. So if you don't want the amp to overheat, you will have to either run the subs in series for a 8 ohm load, or run a sub off of each channel at 4 ohms. That will net 50 watts per sub safely at 12 volts.
Basically that amp is a bad choice for those subs. You can run them, but they won't sound their best.
Car: 84 camaro
Engine: gm crate 350
Transmission: 350 turbo
Car: 1984 z28 camaro / 2019 accord sport
you can get 4 ohms out of two dual 4 subs the amp is rated at 200 rms bridged at 4 ohms and that is 100 rms for each sub
http://www.crutchfieldadvisor.com/le...pedance=DVC4x2
Car: 88 firebird
Engine: 3.1
My problem with these replies are that we are assuming the info. provided is accurate although nothing really makes sense in the original post
sorry the original post was for a friend then he got confused on what he wanted....
so first hes wondering if he could run 2 subs off a mono. and basically i know it would be way underpowered... so no.
the stats are for something he wants...it is a 2 channel fusion amp and 2 subs. he got me confused thinking it was all one question...
db057
08-11-2015 10:11 PM
