Guaging Interest - Kenwood KAC-7201 800W amp/ 2 Kenwood 12" Typhoon Subs
Car: 94 Camaro Z28
Engine: 5.7L
Axle/Gears: GU5 3.23
As stated in the title, i'm guaging interest at this point. I have this stereo equipment that I took out of my third gen, wanting to put in my fourth gen. I've decided, however, that I don't want to take up the trunk space in my fourth gen, so im deciding whether or not to sell.
These are the specs on the amp - it runs for about $150 - $175.
* Cast Aluminum Heat Sink: with Sandblast Finish
* Power Indicator: Blue Logo Triangle
* Bridged Power Output at 14.4V (1kHz, 0.8% THD): 460 Watts x 1
* Maximum Output Power (Bridged):800 Watts
* Power Output at 2 Ohms, at 14.4V (1kHz, 0.8% THD): 230 Watts x 2
* Power Output at 4 Ohms, at 14.4V (20Hz-20kHz, 0.08% THD): 150 Watts x 2
* 2 or 1 Channels of Amplification
* High-Pass Electronic Crossover: 150Hz, 12dB/oct (Switchable)
* Ground Isolation Circuit
* Input Selector: AB/A (Common)
* Quiet Turn-On
* RCA Audio Inputs: Gold-Plated
* RCA Line Outputs: Gold-Plated
* Speaker Connectors: Gold-Plated, Screw-Type
* Speaker Level Input Terminals: Plug-Type
* Stereo, Left + Right, Mono, or Tri-Mode Operation
* Variable Low-Pass Electronic Crossover: 50Hz - 200Hz, 18dB per Octave
* Bass Boost: Off/+12dB (90Hz)
* 2-Ohm Stable
* Copper EE-Core Power Transformer
* Noise Supression Filter: Toroidal
* Power Input Terminals: Gold-Plated, Large Screw-Type
* Power MOSFET Switching Power Supply
* Power Supply Fuse: 40A
* Secondary Capacitors: 2
The 2 Kenwood KFC - W3009 Typhoon 12" subs run between $80 - $90. Specs:
Key Features
* Double Magnet Construction
* Double Spider
* Frequency Response: 25Hz - 800Hz
* Impedance: 4 ohms
* One-Piece Cone Design: with Red Metallic Center Emblem
* Pearl Mica Injection-Molded Polypropylene Cone: 12" Typhoon-Type
* Power Handling: 800 Watts Peak
Woofer Features
* Double Spider
* Impedance: 4 ohms
* Magnet Weight: 63.4 oz
* Power Range: 35-400 Watts RMS
* Sensitivity: 93dB
* Speaker Connectors: Gold-Plated, 2-Way SB-Type
* Urethane Surround: with Perpindicular Inner Wall
* Vented Voice Coil: 2-Layer
* Top Mount Depth: 5-5/16"
Specifications:
Thiele-Small Parameters
* DC Resistance (Re)
* Electrical Q Factor (Qes)
* Force Factor (Bl)
* Mechanical Q Factor (Qms)
* Moving Mass (Mms)
* Peak Excursion (Xmax)
* Resonant Frequency (Fs)
* Total Q Factor (Qts)
* Voice Coil Diameter (d)
* Volume Acoustic Compliance (Vas)
This combo was only in my hatch for about 3 months, never abused, and work like new. If I decide to sell, I would like to see $220 + shipping, negotiable depending on your location. They would ship in original packaging, three seperate boxes. If anyone would be interested in this, please either post here, pm me, or both. Thanks!
* Quiet Turn-On
* 2-Ohm Stable
Key Features
* Double Spider
* Impedance: 4 ohms
Woofer Features
* Double Spider
* Impedance: 4 ohms
* Sensitivity: 93dB
Specifications:
* Force Factor (Bl)
* Moving Mass (Mms)
Car: 94 Camaro Z28
Engine: 5.7L
Now on Ebay - http://cgi.ebay.com/Kenwood-12-Typho...QQcmdZViewItem
efiguy
09-27-2015 01:30 PM
