Dimensions for well sub box
#51
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1986 Trans Am
Engine: 6.0L LQ4
AUDIO ENHANCERS: WELCOME - 20 YEARS OF EVOLUTION IN THE AUTOMOTIVE SPEAKER CABINET INDUSTRY They make dual 12' and 10' boxes for Camaro and Trans Am wells.
#52
Car: 85 Pontiac Trans Am
Engine: wouldnt you lilke to know??
Transmission: TH350 Built to the hilt
Axle/Gears: 4:10 Gears Moser Axle Auburn Posi
be honest with me ... cause i m on a tight budget .... can i take like a piece of plywood cut to 12 in wholes in it , cut it to fit in the well and mount the subs in there or will it sound like crap like i think it will ..... and if it does and i do have to make a box will half in plywood do the job or particle board wich ever one doesnt have like wood chips making it up
BTW that is some funny stuff where the sword dude gets shot
![lmao](https://www.thirdgen.org/forums/images/smilies/lmao.gif)
#53
1 Post
Car: 89 IROC-Z
Engine: 383
BTW that is some funny stuff where the sword dude gets shot![lmao](https://www.thirdgen.org/forums/images/smilies/lmao.gif)
1 sheet of MDF, some liquid nails, and a box of screws is all I needed to build mine, plus the carpeting. Less the carpeting my cost was under $35 I believe.
#54
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
what should i use to seal the box on the iside?
also i have a square 12" l5 sub how would i make the top plate cutout for the sub? and anyone have any ideas about porting it like what size ports or anything?
#55
1 Post
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
I have a pdf file of the dimensions and everything involved that a member posted a while back. He used to have a website and made these for us at tgo.
***see post #62 for pdf***
CL70 (03-24-2023)
#59
Car: 1987 firebird
Engine: 2.8L v6
Transmission: auto
i have 2 12's and am looking for a box that still holds my t-tops safely. What do you guys recomend. Please include pics if at all possible.
#60
Car: 91 RS, 00 TA Ram Air, 86 IROC
Engine: 305 tbi, LS1, 355
Transmission: 700R4, 4L60E, 700R4 NonLU
In my opinion, you need to go ported to go really low. It requires less power and will get lower. My 10" L7 Solobaric is in a ProBox SuperBass rectangular ported enclosure with 1100 RMS and it will make your hair move. It fits perfectly into the well in the back of my 91 RS. The amp is a Memphis Bell. I have the baby bell in my 00 RamAir TA on a ported 8" L7.
#61
How about this?
Maybe this will work.
I hope that helps some ppl. Sorry about the watermark, but it gets the point across. The front and back as well as the sides will still need a few more cuts, but this shows the basic pieces from one 4 x 8 sheet. Not perfect but I used the diminsions from the post at the top of the thread. The piece labled "slant" is not neccessary, it will be made when one of the front/back pieces is cut to make the slant shown in the original post.
Adam
Adam
#62
1 Post
Car: 1986 camaro
Engine: 383 sbc
Emails are getting rediculous for me now about that pdf file. I found that post where I got it so the rest of you looking for the pdf dimensions here it is:
#63
Car: 90 R/S camaro 3.1L stock,
Anyone have the specs like Spartan posted for an enclosure in the sparetire area and/or the storage compartment?
Maybe someone can gather up all these desighns and specs PDF's and such and make a tech page??Cut down on the threds covering the same info.
#64
#65
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Sweet. Just a quick ?, Could I just cut the top peice and then put it on and seal it? So I wouldn't have to do then rest, and only need one peice?
#66
Car: 89 iroc z-28
hey man are those dimension for cutting or just the layout its self if so if im using a 1/8 in ch blade should i just take an 1/8th inch off?? post again thnx
#67
1 Post
Car: 1984 Firebird Trans Am
Axle/Gears: 3.73 Posi
Here's my version of a design presented by Steve "White_Rascal" at the FBodyAudio.com forums It is 1 cubic foot and it will fit one or two 10" subs. Maybe you can even squeeze in a 12" but I don't know. I put in a 10" Alpine Type R SWR-1042D sub.
The first attachment is a GIF image of my version at actual size if printed at 150dpi.
The second attachment is the drawing by Steve "White_Rascal".
Heres some pics of the build process and the final product
![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
![](http://i29.photobucket.com/albums/c267/jaimegmr/Random%20Pics/subbox.jpg)
#68
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
spartyon,
Excellent job............thanks for the file.
Now....just have to buy a table saw and not tell the wife.
#69
Re: Dimensions for well sub box
EDIT: For those who read my response, I do not make custom sub-boxes. Apparently some jackass made these comments when I was away from my computer at school.
#70
i have just one 12" mtx sub, and i like these box ideas, especially the first box at the top of the thread. but i have one 12", not two. so how should i go about building my box? just cut out one hole instead of 2? i listen to rock, and i just want to take the bass off my infinity speakers, so i got a sub. i am not looking to shake the whole world with this sub, but i need it to take the bass off my speakers.
#71
i recently bought 2 15" subs and was wondering if i could use these plans to make the box, but just cut the holes bigger... i love my new subs but a regular box is just plain old boring.... if not does anyone know where i can find plans for dual 15"s or even a place to buy them cheap... i have found a couple of website but none of them offer gray carpeting on the box, only black
#72
Car: 92 camaro RS
Engine: 305tbi
I've only got and want...one sub in my trunk I'm thinking of just cutting those dimensions in half and making the top of the box fill the space...just for looks wouldn't want a speaker and deep well right next to it. Would it be just as easy as cutting the box in half dimension wise?
#75
1 Post
Visualize how the pieces of the box will go together and then measure at least two times before you cut something. Take the width of the table saw blade into account after every cut so you wont end up with short pieces at the end.
#77
Car: 1985 Pontiac Trans Am - PROJECT
Engine: 412 c.i. SBC / 6.75 L
Axle/Gears: Borg Warner 3.27
Brisk mentioned he used this file for his setup, but had to adjust on some of the dimensions. Boy, he was right.
For anyone wanting to do this setup + a false floor going to the back seat, give me about 24 hours and I'll post up pics/specs of the setup I am doing that uses this design, but actually fits... haha
#78
Ok... a little longer than 24 hours, but here goes...
A - Top measure 39 1/2"
Bottom 26 1/8"
Outside indented cuts 9" x 5 3/8" on driver side and 9" x 7 7/8" on pass
B - 26 1/8" x 8 3/4"
C - Top measure 39 1/2"
Bottom 26 1/8"
Outside indented cuts 7 1/2" x 5 3/8" on driver side and 7 1/2" x 7 7/8" on pass
Center indented cut 7 1/2" x 15 1/4" (almost 100% positive this is centered at the top)
D, G - Outside 10 1/4"
Inside 8 3/4"
Bottom 8 3/4"
Top: Connect the outside and inside edges
E - 6 1/4" x 10 1/4"
H - 10 1/4" x 8 5/8"
F, I - Outside (I forgot this measurement) Measure to fit your box
Inside 10 1/4"
Bottom 8 1/2"
J - 16 3/4" x 7 1/2"
K - 15 1/4" x 3"
L, M - 7 1/2" x 3"
False floor - Seat side 44"
Tails Side 42 1/2"
Width 34"
A couple of things to be aware of...
FIRST, ALL measurements may need adjusted for your car. But these are pretty exact to the pieces in my setup here: https://www.thirdgen.org/forums/car-...etup-look.html
SECOND, the 16* angle shown in the PDF is dead on.
THIRD, you will have to add some kind of support braces for the false floor close to the seats.
FOURTH, I used 3/4" mdf for everything BUT the B and J panels. They are 1/2" in my setup. This affects the setup's measurements.
Any questions, feel free to ask. Happy building!
Bottom 26 1/8"
Bottom 26 1/8"
Inside 8 3/4"
Bottom 8 3/4"
Inside 10 1/4"
Bottom 8 1/2"
K - 15 1/4" x 3"
L, M - 7 1/2" x 3"
Tails Side 42 1/2"
Width 34"
#79
Car: 87 irocz
Engine: 355 tpi
Axle/Gears: 373
I had the idea of taking my back seats out i mean its basicly a two seater anyway and putting two 12's there in a custom fiberglass box with neon lights i have a orion hcca amp that puts out over 1,800 watts & its 1 ohm stable im just trying to find the time to build this box ive been dreaming about
#80
Does anyone know the dimensions to make it two separate boxes? I assume it's just a board I'd add, but I'm not sure where. If I end up calculating it I'll post the location of it.
#81
sorry it won't let me edit my last post, but I figure this deserves to be put in this thread. http://i18.photobucket.com/albums/b1...T-TopRiser.jpg
It's my idea that lets you use your T-Tops and mount the amp in the middle with the enclosure plans listed earlier (the PDF). Also, I'm posting in here because it's stickied, and is directly related. I figure maybe it'll help someone else (note in the pic, the subs and enclosure aren't exactly to scale, but the riser is). The riser is 2ft long on the back, 3inches tall, and has 6inch wide legs. 15" long sides, and the interior leg side lengths are 6inches long. If this is unclear say so, and I'll add the dimensions to the pic.
also sparty's design can easily built with a circular and a jig saw. No need for a table saw.
#82
Car: 1999 Jeep Grand Cherokee
Engine: 4.7l PowerTech V8
ok you guys, in the pdf file provided in here, it says the top mount depth for the subs is 5.25" or 6" is this true b/c otherwise my sub selection will be very limited. im looking into these http://www.caraudiocraze.com/subwoof.../prod_861.html
but i dunno if theyll fit. thanks
#83
Car: 91 RS Vert.
Engine: 350 TBI cammd
Please forgive me if this has been answered before but would these dimensions also work for a 91 convertible? Als i apologize for reviving a older thread
#84
Location: I live just across the border from detroit in a town called windsor in ontario Canada
Car: 1992 Firebird convertible
Engine: 5 litre 305 tbi
Transmission: Automatic
Axle/Gears: stock 2.72
does anyone have or know the angles for the mitre cuts, like the 8 inch slant and the 2 4" and the 1 9" parts. thanks a lot
#85
Car: 89 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Transmission: 5sp Standard (t5)
Axle/Gears: 3.42 true trac
I made a sytem for subs as well, except i didnt make a whole box for it, i just made it with the top plate of what u would use for the box and put it on hinges so it can flip open and you still have the space underneath, i mounted my amp on the bottom of the trunk well, ill post pics later, im curiouse to know how u kept the sides straight and be able to put it in past the metal rings cause i had to cut in a litlle bit so it would clear them and fit in.
#90
Car: 92 RS
Transmission: TH400
Axle/Gears: 2:73
can anybody tell me which would be better for my 2 12" L5 a ported or sealed box and what dimensions and a list of what i need to make the box
#92
Car: 1991 Z28 camaro
Engine: 305 TBI
Transmission: 460LE
Axle/Gears: 7.5 rear end richmond 373
Well everything ive heard says ported is better 4 over all loudness were as sealed is better 4 sound quality in my z28 i installed a single 12" hiffonics brutus sqaure in a custom box and thats enough to get u pulled over!!
#94
I did, me and my dad built a ported box and had to seperate them internally for airspace. I think it's pretty sweet and the price was right, maybe 100$ for random stuff. All the components are all my dads left over old stuff.
ps. sorry for kinda stealing your setup demitri.
wow gotta love the grey interior that looks purple. Stupid camera
#96
Car: 92 Z03 RS TBI
Engine: 5.0 L03
fyi it's not symmetrical, so you can't just put a wall in the middle. You'd have to measure and calculate the actual center. But if you're running two subs that are brand new and teh same, what does it matter? as long as they both work you're not gonna blow one.
#98
Car: 1985 Z28 Camaro
I have two rockford fosgate punch p2 twelves and i need to know if any mods will need ot be made to accomidate the air space for them or if it will be okay without any modifications
#99
Car: 92 Z03 RS TBI
Engine: 5.0 L03
I would check the minimum space allowed. I think the box works out to a little more than a couple cubic feet. You can add baffling material (not sure of exact name) to make it behave like a larger volume, but not much. Check the manufacturer's website or it should be listed on the box the subs came in.
#100
Just to let every one know i have a program that will make the demionsions you need like you measure ur space and then put it in demensions and make a box. Its very easy software and i am willing to share FREE. i got it from a buddy of mine so just pm me and i will send it its called probox which is easy. CHeaper to make ur own box than to buy a premade. its time consuming but sure worth the effort.
Twitnoid (09-08-2020)
