Is this a good sub box design?
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
http://cgi.ebay.com/ws/eBayISAPI.dll...773975991&rd=1
Is that a good one for a pair of Audiobahns, or do I need a sealed box? I know nothing about porting lol
Car: 83 camaro z28 cross_fire
yea its an alright box but you have to match the specs such as ported box volume of the sub to the actual volume of the box.
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
ya... I know. But, just looking for friendly advice!
AW-1251Q is the model.
Sensitivity: 92.1 dB
Min Frequency Response: 24 Hz
Max Frequency Response: 1000 Hz
Depth: 5.25 in
Audiobahn recommends a ported box, with the following specs:
Air space 2.5^3
Port size (1)4x6.9
Port Vel. 7.64%
-3db 33.5Hz
Tune freq. 37Hz
Sub disp. .15
Port disp. .044
Total vol. 2.7^3
Ok, so I need a box with two 2.7cf enclosures??
Depth: 5.25 in
Air space 2.5^3
Port size (1)4x6.9
Port Vel. 7.64%
-3db 33.5Hz
Tune freq. 37Hz
Sub disp. .15
Port disp. .044
Total vol. 2.7^3
Car: 1992 Firebird T-Tops
Engine: V6
Hope you have some tricks you can pull to put a 5.4cf box in a thirdgen.
I think 37 Hz is tuned too high as well, but maybe Audiobahn knows something we don't if they're suggesting that tuning frequency. It's your call.
Car: 1989 Iroc-Z
Engine: 350 tpi
Transmission: Swapped in T5
ok a lil help from me. i have two 12" audiobahn flame excursion series subs in a pro box. itsa custom built for our car and it helps the perfromance of the subs. check em out. www.proboxrocks.com
Engine: V6
Originally posted by aaron7
Ok, but Audiobahns suggests only ported for them, how could I find sealed box specs?
It's crazy to buy a ported box for a sub that is not tuned specifically for that particular sub. It's easier to buy pre-made sealed boxes because all you need to worry about is the volume of the box.
Engine: V6
You can download it here:
http://www.linearteam.dk/default.aspx?pageid=winisd
Anything else just leave a message
Engine: V6
Once you open the program, go to the "help" menu and click on "how to begin." It has a pretty nice tutorial. You should probably do some reading about Thiele-Small parameters online if you don't really understand them. This website is pretty helpful for that:
http://www.carstereo.com/help/Articles.cfm?id=29
backtothe80s
09-05-2015 12:39 AM
