Is this even feasable
I did a search, but results are not satifying.
My question is, would it be feasible to get one of these big home stereo and install it in my car??? I tough of this and I don't have a clue on feasability. I'm no wise men in electronics so don't be too hard on me.
Car: 83 z28
Engine: 300hp 355
Re: Is this even feasable
you'll get a lot more power and output from a car amp
I was talking about a complete setup: "head unit" speakers and subwoofers.
and I juste checked on the JBL site, the price indicated is 549.99$ and for the price , no speakers no sub, no cd player.
Car: 83 z28
Engine: 300hp 355
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
yea the reason is that they are big... clunky.... need a power inverter..... and may be difficult to mount
what do you mean poserbahn.. audiobahn has some really good stuff.
go to ebay and buy some Poserbahn I mean audiobahn
Car: 1988 Camaro
Engine: 173 CI
Axle/Gears: open 3.42's
audiobahn may not be the best stuff but for the price you cannot beat it i have an 8000t and a 4002t in my truck and i love them.
Car: 83 z28
Engine: 300hp 355
Car: 92 caddy PIMP
Engine: 4.8
Transmission: i dunno
Well I cant say it enough. You get what you pay for. If you want subs in your trunk your GONNA spend some money. No doubt about it. Is putting a home stereo possible? Yes. Is it gonna get you laughed at and prolly cost you the same in the long run. Yup....
You should first of all check out ebay. Theyre wicked cheap.
Head unit-dont get anything without a preout for the subs and please dont buy sony or jensen.(dual)---AKA SPend the money on a quality unit. Mine plays mp3s and has triple 4V prepouts...200-250+shipping on ebay. I paid 300 at CC at the time...
normal speakers-your gonna want something more then your paper factory ones. You dont have to get high priced stuff right away here alot of aftermarket stuff should keep you satisified for a little while.
wiring-Its prolly gonna be about 25 for a decent set of wires...Dont go below 4 gage power!!!And please hide it.
Amp-While you can get a 1200.1 JBL amp for 250 on ebay. Id look into cheaper stuff if price is an issue. Just dont buy no name brands such as pyramid.
Sub(s)-match a sub or two up to your amp. Look at RMS. NOT max power.
Box-If your decent at woodworking you can build your own box. Im sure alot of people here actually have the dimensions and drawings. Also make sure to go with a close airspace to the indication on the subwoofers. Sealed is generally for more tight bass and ported/bandpass is more lift your hair booming bass.
In conclusion. Your best bet is prolly classified sites or ebay. Its up to you though. Let us know.
Thanks for the advice. I had this idea and threw it aroud.
I'm not so fond of ebay considering the fact that you can't know for a fact that the stuff your buying is not already kaput ( please tel me if I'm wrong).
As I did with other inquiries, I'm just trying to get the most out of the least money possible so that I can enjoy my car the most possible.
Car: 1986 Pontiac Firebird
Engine: 1991 305 TBI
Transmission: Th700-R4
I'd disagree with the 4-awg comment. 8-awg is perfectly acceptable when your under 500watts. At least dont do what my firend did and use two 12-awg speaker wires for power
If you can fit a home audio reciever into your dash, you'll certainly have my undivided attention.
But by the time you cough up the money for a massive power inverter that can supply enough power to the receiver, your finantial investment would certainly have been more than if you just bought an inexpensive head unit and a solid amplifier made for the car.
There are plenty of bargains out there if you look for them.
1 Post
Car: 91Z
Engine: 355/afr/sr/lpe219
Transmission: built 700R
Car: 1985 Firebird
Engine: 3.1L (planning for a turbo)
You guys just gave me a hell of an idea.... we've got some cheap (like 60 dollar) home theater systems. 5.1 Surround sound, like a 100 watts (not much but we've got a 150 watt setup in my living room and it shakes our 90 year old brick house...) I'm gonna show guys somthing awsome in the next few months...
Car: 92 caddy PIMP
Engine: 4.8
your decision but car audio is meant for car audio and home theature is exactly that. But be sure to give us pics and a review if you do do it. LOL
Ebay is good for closed box stuff too. Its already "wrapped in plastic" still and alot cheaper. You can go auction style sent from users but as you said you have a chance of it being broken.
As for my power wire comment. 4 gage is just in my opinion a good wire to use if you ever plan on upgrading. If you never plan on adding amps for your stock speakers or your never gonna upgrade your subs then its fine. But power wire is pretty cheap anyway. So to each their own.
Id also like to add that unless your gonna be watching movies you usually dont need surround sound in your car. And the woofers they include in those 100.00 dollar 5.1 systems are laughable.
Just adding my opinion.....
Nate
Nate
Car: 89 IROC-Z
Engine: 355 TPI
Originally posted by ddn69
...and please dont buy sony or jensen.(dual)...
...I'm gonna show guys somthing awsome in the next few months...
No. If you are not a wise man in electronics, don't try to attempt this. There's a difference between saving money and being cheap. Car audio equipment is more expensive because headunits require that all the hardware be built into an enclosure small enough to fit in your dash and withstand vehicle vibrations, amps are built with the same rigors in mind, and speakers are designed to withstand extreme temperature and humidity changes daily. Forget trying to play a CD in a home audio CD player in a car... home audio equipment doesn't need nearly the amount of shock and skip protection that car CD players do.
Car: 1985 Firebird
I'm not gonna do it to prove any one wrong, I'm gonna do it cause I can, and to be different. if dose end up sound horible, I'll save my recits and get my money back I like doing weird things.
Car: 2000 Trans Am WS6 (Black)
strange indeed.... I wouldn't even buy a 5 channel car amplifier, because its cheaper to buy two 4-channels instead...
they make 5,6, and 7 channel amps for cars if you look hard enough.
Just think about this... a Power Inverter that can TRUELY power your little "home theatre"--for $150?? I assume from Wal-Mart or RadioShack, would cost MORE than your home theatre system!!!
Since a quality 700watt (PEAK) inverter (squarewave, no less,) costs close to $100... thats 100 bucks you could have bought an entire 4-channel amp for, NEW off ebay.
Try and hide this home theater in your car, and watch the amp cringe with your low-impedance car speakers running on it... (many of those CHEAP theaters use 8ohm+ woofers) -- not saying that good systems (in homes,) don't use high-impedance too, I'm simply pointing out that your car woofers are usually not as high.
The only thing that's impressed me out of the home theater area are bookshelf speakers. I put two Sony 3-ways with 6" bass woofers in 'em, and they sound much better than 10" subs in the rear, plus they can get friggin' loud with low distortion... these speakers are from the early 90's if that clears up anything....
Car: 1985 Firebird
No no, I'm talking about the ultra cheap home theater systems in box we have at wal-mart (I work there so I also get 10% off) the amp is built into the reciver, and the whole system is only about 130 watts peak. For like 39 bucks. Seriously its a really cheap system but for the money sounds very nice. (in a home setup, so I'm thinking in the car it should be decent.)
And who said I was going to hide any thing:lala:
they sound good in a home because you have bigger speakers, and bigger rooms... in a car you have to compensate with more power, and better speakers... because you have less distance between the speakers and your ears... which also makes it harder for your speakers to create good bass (in a car)
Car: 92 caddy PIMP
Engine: 4.8
forget it. Let this kid do as he wants. I mean he obviously isnt gonna see you get what you pay for....Walmart no less. Itll prolly break in 2 months not to mention its going to be in your CAR where its not supposed to be.....
Nate
Nate
And don't try cheaping out on the power inverter, too. Or the wiring supplies you'll need. You can kiss your car goodbye from the resulting electrical fire.
Car: 1991 Camaro RS
Engine: 357cid
if you decide to go this way anyhows get good pics of teh fire while and after it happens
oh yeah... what I meant by bigger speakers... is that the BOXES are huge... you're right, the actual woofers are tiny, and will sound like crud in a car.
but I agree, if he does this, I'd be interested in seeing some pictures..
maybe if you find a power invertor for free, and already have a home theatre amplifier laying around, it would make more sense.
Car: 1985 camaro
Engine: 2.8 MPFI
For no more than $400 on ebay can you buy a decent HU and 4 speakers...correct me if im wrong im not super familiar with ebay but you can have a loud good sounding system for not too much and then another 400 for an amp n subs n a box....once again correct me if im wrong
Car: 1991 Camaro RS
Engine: 357cid
id rather have a good sounding system than one thatll make small animals die and my ears bleed
in combination with ebay and walmart... you could:
1. get a 1500 watt hifonics amp for your subs - $239
2. get a nice 4channel hifonics amp - $180
3. get a cheap wiring setup from Walmart or build it yourself - $40
4. for another $300 you can get a VERY nice set of 12-15" subs
5. find a local shop or build a box yourself--- $20-$100
6. Find a headunit off ebay... my 8600 is $259
7. purchase various hq comps/coaxials... $300
total for a killer system = $1338-$1418 of ebay... if you got it from a car audio store... more like $7,000
that hifonics amp sells at my local shop for $1200!!! yeah right
FireDemonSiC
10-13-2008 09:08 AM
