I'm getting myself an early Christmas Present basslink X or T????
I don't know which to get, T looks cooler, but X is more what i need.
Here is a picture:
It mounts Vertical, but would it look okay sitting on the hump in my '84? The highrise in the back? If I sit it in the back trunk area will it sound bad? I want the most bang for my buck here, I also would be curious to know if I mount it on the hump and drill holes would a hard break session send it flying toward me?
The 1 woofer system runs about $215 and the other a bit higher at 300 or so, it looks like 3 subs but it isn't. The X has 1 passive and 1 10". The other has 2 passive 1 10" WHICH WOULD SOUND BETTER? I read reviews but they are all biased crap off of sites trying to sell their product lol
Dimensions on the 3 woofer design is (H x W x D): 14-3/8 x 40-3/8 x 6-7/16
and the Basslink X is: Dimensions (H x W x D): 14-1/2" x 12-1/2" x 8
Choices choices.
If anyone tells me the BEST way to mount this thing I will send you thousands of e-hugs
Here is a picture:
Choices choices.
Car: 92 caddy PIMP
Engine: 4.8
Transmission: i dunno
Is that actually 3 woofers?(I think its one woofer and the other things are something else) Also DONT mount down the enclosure without placing a piece of wood underneath the carpet as the gas tank is under there.
If your strapped for cash you can make your own box and go on ebay for your amp/sub combo....
Nate
Nate
These are self amplified, 200 watts so I don't have to F### with an amp and speakers ect. Its kinda a turnkey operation LOL
Eh, I posted those are passive, the other basslink has the exact same thing on the other side. Resonators or something
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
um what kinda bass are you looking for...... becuz i think for 250 to 300 you could get a quaity 12 in a powered box.... shop around and you'll find tons of deals.
also by not f-in with an amp and speaks all you are avoiding is buying a separate amp and wiring the speak to it.... you still need to run power to the amp and run the signal..... in ll i think if you look around you could put some really thumping bass for around 300
(im looking at audiobahn alum12q subs that can be had for 110 or so dollars and an enclosure could be up to 100 for a quality one, then find a good decently priced amp and you in biz... i think i had found all this for around 300 less the wiring kit for the amp which you need anyways)
Car: 86 sport coup
Engine: 5.0
the basslink T is for suvs the clear bass link is a good lil toy 200watt 2 10woofers 1 powered and 1 passive driver. go for the clear one.
Z28/ZR1
10-23-2015 01:04 PM
