2 amps 1 set of pre outs
Old 09-27-2004 | 09:56 PM
BRYAN BUSH's Avatar
Car: 91 Z28
Transmission: BORG-WARNER T-5
hi am hooking up 2 amps but only have one set of pre outs on my head unit.I have done it before but i forgot how.I think i hook it up to the one that has a pass-thru connection.Then i hook up the other amps input to the pass-thru connection.Any help would be great
Old 09-27-2004 | 10:07 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Well when I had the audio shop first do my subs (big mess) they hooked my 2 subwoofer amps up to my HU and it used a Y splitter. They ran the RCAs from the HU back to the subs then used 2 splitters so I could get the right and left connection to both amps.
Old 09-28-2004 | 01:51 AM
screamin' 85 z's Avatar
Car: 85 IROC
Engine: 355 CI n/a
Transmission: 700 r4 w/3500 Coan
You can use a Y-splitter like the one above, OR if one of your amps has a pass through, just run 1 set of RCA's to the amp that has the pass through, and the other set from the pass through jacks to the other amp
Old 09-28-2004 | 02:54 AM
BRYAN BUSH's Avatar
Car: 91 Z28
thanks for all the help
RazorN8
01-07-2022 12:44 PM
thefirebirdm@n
South Central Region
09-14-2015 02:45 PM
89mulletbird
08-12-2015 08:08 PM
ZsTransAm
08-11-2015 08:30 PM
