Bose radio from 4th gen help please
Car: 1991 Camaro RS
Engine: Stock 305 TBI
Transmission: Stock
Hi, not having much luck with the search, hopefully someone can help me out.
I picked up the bose system from a 95 camaro. Radio, speakers, and a strange little box.
can anyone point me to a wiring diagram directions for installation or anyone that has done this before? I'd really appreciate it.
Car: 1991 Camaro RS
Transmission: Stock
I've got the whole setup. Harness, everything... Just curious if there is a diagram that shows where to plug in everything or if anyone has done it before.
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
I have the Monsoon unit from a 2002 and just used the head unit and plugged in my standard 4 speaker wiring harness connector and it works fine w/the 4 speakers. If that's all you want just plug it in and go. No splicing is necessary that way. The Bose might be the same way. Can't help with adding the amp and extra speakers, sorry.
Car: 88 Camaro
Engine: L98 350
Not sure but I think the Monsoon is a conventional stereo with head unit powering the speakers, with a separate sub amp and speaker. Bose unit has separate amps at each speaker/enclosure. First diagram of Bose unit for 93:
You're right about the single sub amp on the monsoon system, I stand corrected. Sorry for the error....
db057
08-11-2015 10:11 PM
