Can a 2 Channel Amp Power 4 Speakers?
Car: 1992 Firebird Formula 350
Engine: 5.7 TPI
Axle/Gears: 3.23 Posi
Please excuse this newbie question, but I was just wondering if you can use a 2 channel amp to power all four speakers, and if so, how do you recommend wiring it? I don't care about the ability to fade, so that's not an issue. Thanks.
Car: 1986 Camaro SC
yes it can be done quite easily, i'm running my 4 speakers plus one sub off my 4 channel, just make sure your amp is 2ohm stable if you are using 4ohm speakers, then just hook up your 2 +s for teh front speakers into one + on the amp, and the same with the negatives and rear speakers, you will lose the ablilty to fade tho
Engine: 5.7 TPI
So if the amp has both R + and - and L +and -, fronts go to the left, and rears go to the right? Could I put front and rear right on the right and do the same with both lefts? Then in theory the balance should still work.
sailtexas186548
08-24-2015 10:11 PM
db057
08-11-2015 10:11 PM
