Which amp for 2 PIONEER TS-W300R 12" subs
Car: 1989 Iroc-Z Camaro
Engine: 5.7 liter 350
Alright, bought two cheap cheap PIONEER TS-W300R 12" subs
Subwoofer Specifications
Rec. Sealed Box Dims: 1.25 - 1.75 cu.ft.
Rec. Ported Box Dims: not recommended
Free Air Usage: not recommended
Sensitivity: 91 dB
Frequency Response: 20-4,000 Hz
Recommended RMS Power: 150W
Peak Power Handling: 600W
Impedance: 4 ohms subwoofer wiring options
what sort of amp would be ideal for running two 150W RMS subs at 2ohms? does that mean that I just need a one channel 300w rms at 2ohms amp?
Or does it mean that I need an amp to do 150W rms at 2ohms?
or would a 2 chennel amp with 150w rms at 4ohms x2 be better?
Any suggestions greatly appreciated.
**also, what kind of wiring to the cargo area, and what wiring between subs and amp?
Sensitivity: 91 dB
mtx 421d would work well, coustic 401db, hell, almost anything with ABOUT 300W rms @ 2 ohms would work well for you.
i would go with the 421d, 3 year warranty if installed by an authorized dealer, very strong for the cash, should be able to get it for under 225$.
adam
adam
ok, thanks a ton, just wanted to make sure I needed it to be 300 at 2 ohms not 150...I think I'll get it online, cheap =)
have at it, but i wouldnt.
if you go talk to your local specialty car audio shop, NOT best buy, circuit, etc. and ask them to hook you up, you would be amazed at how cheap you can buy the stuff.
buying mainstream gear off the internet is dumb. IMO
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
If you know what you're looking for, you can find some goodies on the net.
Find yourself a JL Audio 300/1 amp, you won't be disapointed!
the local stero shop will sell it for $300-$400
you can score one on the net for $150 maybee, but if you want piece of mind, buy local.
I would not mess with MTX....JUNK.....just my opinion.
i disagree, i sell mtx, along with pioneer, kenwood, xtant, eclipse, memphis, arc audio, focal, rainbow etc.
mtx is good power for the money, there are cleaner and better quality, but dollar for dollar they are hard to beat.
adam
adam
Engine: 2.2
Lots of stuff gives 'bang for the buck' if MTX works for you, then go for it.
I've never been too impressed with most of thier stuff.
I have seen some good sounding systems here and there, mostly in trucks with huge boxes with 3 10"s or 12"s.
The subs are ok, but there are better amps in my opinion.
no, there aren't alot of bang for the buck companies.
i compare MTX to fosgate, kicker, and all of the other lower end gear, and they hands down win IMO.
i can think of some amps that are better, and i can think of some that are cheaper, but MTX stuff is a good value, especially thier class D stuff.
adam
adam
alright, I bought this 4 month old one for $100 + $20 s&h, good deal i think, total speaker amp cost is still low.
MTX Mono Thunder421D Class D Amplifier
RMS Power 12.5 VDC Input
Hi Level w/ Smart Engage
Low Level Input
Crossover(s)
Low Pass @ 40Hz-200Hz - Variable
Thunder EQ
EBC2 Port
RCA Output
Low Pass Only
2 Ohm Load 300 w x 1
4 Ohm Load 150 w x 1
Dynamic Power 14.4 VDC
2 Ohm Load 420 w x 1
4 Ohm Load 210 w x 1
Dimensions (with ISO Feet)
9.4" x 9.75" x 2.1"
23.9cm x 24.8cm x 5.3cm
Low Level Input
Crossover(s)
Thunder EQ
EBC2 Port
RCA Output
Low Pass Only
9.4" x 9.75" x 2.1"
heh i just bought a $400 79 corolla hatchback with 144k miles...my beater, dunno if i wanna put speakers in it or not, im gonna drive it more i think, maybe just 6 1/2 and 6x9's
Engine: 2.2
$2.07/ gallon, you sure will drive it more!
Mine's going on 185k and still runs fine. You can have some fun with the hatchback, much like thirdgens! Good for bass
I had a '78 celica before, $200, it was a piece of junk. I used to drive it around unregistered before I got my license..I had to dump it because it had no hopes of passing inspection. Aside from the rust, it was a decent running car too.
the corolla seems great, first car ive ever driven manual, and i like it, i dont need to worry about rolling up windows, or locking doors....has a cool looking body in my opinion, needs paint, but no reason to make it look pretty...its whole apeal is that i can park it anywhere worry free......i love my new car, and i have the camaro to impress if i want to, though it looks crappy compared to ones on here....the 5.7 is enough to impress most of my friends
now back to subject, how am I going to wire this all up, if anyone could supply me with info on going from stock speakers to adding an amp and 2 12''s, I have a pioneer cd player, and 2 6x9's and 4x6's that need to go in too, but i think thatll be ez
raymondandretti
09-27-2015 06:43 PM
