Need help with center channel speaker hookup
I am trying to find a way to hook up my tweeter that's mounted in the headliner as a center channel speaker. If I hook it up to one of my receivers outputs I will only be getting the sound intended for that side be it left or right. And a receivers speaker outputs can't be bridged which I assume would let it act as a center channel speaker. I've looked for receivers with center channel outputs but they are all DVD receivers with LCD screens and extremely expensive which I don't need nor have the money for. Any help would be greatly appreciated.
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Something I read about and tried years ago was to connect each speaker terminal to the + output from each side of the deck/receiver, and use a 15 ohm, 10 watt resistor in one wire. That car (81 Ford Thunderduck) had three speakers in the dash, which was not great for imaging, so the third speaker was barely noticeable.
why do you want a center channel if you arent listening to dvds?
So use a pos. output from each front output (L and R) and put that resistor in just one of the wires? Where can I get a resistor like that at?
I just found this
The center channel wiring is done by putting 2 - 25 Watt 4 Ohm resistors into the tweeter circuit. Here is how to wire it. Take the L (+) speaker output from your receiver, hook it up to one side of the first 4 Ohm resistor, take the other end of the 1 st 4 Ohm resistor and hook it up to the tweeters (+) crossover terminal. Duplicate the process for the R side. Take the R (+) speaker output from your receiver, hook it up to one side of the second 4 Ohm resistor, take the other end of the 2 nd 4 Ohm resistor and hook it up to the tweeters (+) terminal also. (both of the 4 Ohm resistors output ends hook up to the tweeters + crossover terminal) Hook up the tweeters (-) connection to the (- ) speaker output of the receiver (or chassis ground in some cases). This configuration gives you a summed front center channel tweeter for proper sound staging.
Is that put into easier words?
