How to wire 2 6x9's and a sub
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
How would you wire that. Would you need a 2 channel? a 4 channel? Can you run a 4 channel with 6x9's in 2 channels, and then a sub bridged on the other two?
A wiring diagram would be great.
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
all of the above.
Car: 85 firebird
Originally posted by br()bert
all of the above.
all of the above.
Re: How to wire 2 6x9's and a sub
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Just make sure the amp can power that sub.
I had a Pioneer 4ch amp that was only 300watts (probably more like 100watts usable though) and it would barely move my JL 8W6. you'd have to touch the cone to feel the movement since it moved so little.
If you haven't purchased anything yet, see what you can get for the money you have allocated for the amp(s), sub(s) and speakers.
Glowsock
01-09-2017 04:06 PM
