possible to put subs on rear shelf behind backseats?
Old 01-20-2004 | 09:53 PM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
has anyone managed to successfully come up with a way to add subs and an amp to the shelf area behind the backseats? im thinking about subs in the future but i dont want to loose the rear cargo hole. theres not much area to work with there is there to install some subs and an amp huh? i also want the pulldown cover to cover whatever is there when the hatch is closed so that even hurts more.
is there anyway to convert the stock rear speaker holes to become a sub encloser and stick subs in there? i know you'll loose mid and highs in the back but i think a good set of 4x6s up front will keep things sounding ok.
just wondering if anyone has come up with a "decent" sub setup without loosing that trunk space. ive thought about door subs but i dunno if i like the idea of that.
Old 01-20-2004 | 11:08 PM
white91formula's Avatar
Car: 91 formula
Transmission: t5
i believe that with a little work you can get 8's to fit in the sail panels
Old 01-21-2004 | 01:09 AM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
Sail panels in our cars suck as far as bass is concerned. I thought about putting 8's in mine but you gotta think about this, even a decent 6x9 doesnt sound all that good in the sail panel as it does in a box type enclosure so a 8 wouldnt produce all that much bass either when istalled in the sails. I've seen people put some 6'1/2's in the sail panels and then put a small box with a 10" sub in the spare tire area along with a amp or you can also put the amp in the glove compartemnt area , just remove the cardboard inside you'll gain some room.
Old 01-21-2004 | 01:31 AM
flrtin1's Avatar
Car: Z/28..39 Plymouth truck in progress
Engine: S/B
Transmission: Manual
I have two 12's in Q logic boxes w/crunch amp mounted inbetween dont have a pic handy but can get u one if u want still have the "hole" open
Old 01-21-2004 | 04:48 PM
TekViper's Avatar
Engine: 3.1L v6
flrtin1 can u get the pic, not sure what u mean by inbetween.
Old 01-21-2004 | 04:55 PM
flrtin1's Avatar
Engine: S/B
Ya, I will get them on thur. you will see in the pics the subs are in seperate boxes and with them pushed to the inner fender covers there is enough room for the amp to sit on the shelf between them
Old 01-21-2004 | 09:23 PM
flrtin1's Avatar
Engine: S/B
Hey Tekviper I posted the pics on my web site (they got on me about too many pics on the board) they are at the bottom of the page http://www.geocities.com/thirdgenblownz28
Old 01-21-2004 | 10:06 PM
TekViper's Avatar
Engine: 3.1L v6
thats looks like pretty much what i wanted to do but is it possible to fit a box that wont interfer w/ the hatch cover? it doesnt seem like a likely possibility at this point but i was just wondering if anyone figured some ingenious way to do it. what about a really thin long box with 1 speaker. would that provide enough volume to make the single speaker sound ok?
Old 01-27-2004 | 03:03 PM
SLOWFIVEOH's Avatar
Car: 82' Z28 IROC Clone (SOLD)
Engine: 355
Transmission: Built TH-350
Axle/Gears: 3.73 Moser 12 bolt
I did that last year, I had (2) Rockford Punch XLC 12s in a pretty decent size sealed box and my amp mounted to the box sitting on the rear shelf, I cut down the height of the box by 3 inches and it was just clearing the rear glass, But it looked killer. But now I am building a glass box for the well, Seems much more stable to me.
Old 01-27-2004 | 09:29 PM
Zombie_89RS's Avatar
Car: 89camaroRS
Engine: 406
u...can....try....this
sorry.....for...the.....periods.....my....spacebar......broke...
try....going....with....one.....kicker.....solobaric.......12..
and..an....amp.....alot.....of...people.....dont...care....for...just...one.....12.....but...the......kicker.....sounds....great....alone.....
and....doesnt....take...up...much.....room....and....ull...be...able...to....use...the....cover....u.can....
email...me....at....jd2003aic@aol.com......and...i...can...hook...up...with...a..few..more.ideas......depending...
on....how...loud...u..want...sorry....again...about.....
the....spacebar....new....keyboard...tommorow
Old 01-28-2004 | 03:05 PM
demicon's Avatar
Car: 89 Firebird
Engine: 2.8 MPFI
cansomeonepleasehelpmefindmyspacebar?
hee hee..
couldn't resist.
Old 01-30-2004 | 12:56 AM
A88GTANotchback's Avatar
Re: u...can....try....this
THE TROOPER AWARD goes to, ZOMBIE. for never giving up typing in any situatution:hail:
Frozer!!!
01-19-2024 05:55 PM
1992 Trans Am
05-10-2023 08:19 PM
customblackbird
08-15-2021 11:16 PM
TreDeClaw
Theoretical and Street Racing
06-22-2021 09:21 PM
