Sub Box, Cu. Ft. dilema!!
Car: Camaro
hey i'm building a custom box... for 2 10' JL Audio subwoofers, i'm probably gettin W3's.... but the way i got this box designed i will only have like 1.16 cubic feet but i wanna put a divider in leavin me with like .508 feet per sub.... sub recommendation is .975 or something... will i be able to do it still or am i askin for trouble by cheatin the space... ??? not sure what to do ? ?
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Did JL give a range of airspace? If the bottom end is .9 and you do .5, it wont sound good at all, esp if its ported.
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Re: Sub Box, Cu. Ft. dilema!!
Car: '81 Trans Am
Engine: 6.6L
Transmission: auto 350
some ppl believe that filling the box with something like fiberglass insolation will trick the sub into thinking its larger box.
also some ppl mount them in upsidedown to get alittle more internal volume.
Car: 89 Formula L98 power
Engine: '96 subaru, opposed 4banger
Transmission: TH700R4, subaru 4WD
Axle/Gears: 3.27, just works
actually, when you fill the box with roughly 50% of polyfill(safer than fiberglass to handle) it doesn't trick the woofer into thinking its a bigger box, it makes the airflow behave like its a bigger box. By adding 50% of fill to the box, it actually slows the air down, making the woofer behave in a manner similar to a larger box, but anytime you have a woofer in a box, you want some kind of fill as it buffers any muddiness and cleans up the bass, makes the woofer more responsive, and you have less resonant waves bouncing around inside the box, so the woofers surround takes alot less of a beating while pounding away.
Originally posted by cronsformula350
...... it doesn't trick the woofer into thinking its a bigger box .....
.....you have less resonant waves bouncing around inside the box, so the woofer....... takes alot less of a beating while pounding away.
Car: '81 Trans Am
Engine: 6.6L
yes thats what i ment. But ive tryed both ways in my box with and w/o and i liked w/o better. No hurt in trying it.
yeah sometimes the fill doesn't make much of a difference.
Car: '81 Trans Am
Engine: 6.6L
Originally posted by Jim85IROC
Good quality fill can fool the sub into thinking it's in a 10-15% larger box...
I like polyfill, its for sale at walmart, and is pretty cheap, its as good as pretty much everything else available. Its safer to handle than fiberglass, and is like 2.50 for a 20 0z. bag. A friend of myne told me also that some car stereo mag said it was great for boxes too, even though I used it before I knew about it being so great.
Car: 1992 Camaro RS
Engine: 5.7 V8 TPI
Transmission: T-5 5-Speed Manual
the other option is to build an Isobarik subwoofer box, but that involves another 2 subs & isn't quite as cost effective
Originally posted by jcurrieirocz
What kind do you recomend or what kinds are good?? Im still trying to think what i used.
I've never used it personally, however, so I'm going by what I've heard on some of the DIY audio forums.
Yeah I saw that stuff from parts express, but I was too lazy to spend the money on it, I'm sure it works as well if not better.
