4x6 Dash Speakers What Will Fit???
Car: 91 rs
Engine: Carbed 355 CR 9:1 xr276 cam
Transmission: 700r4 2600 stall
I did a search and saw that there were several brands being used. I went to crutchfield t g3et an idea what wil fit a 91 rs without bose and with power windows only 3 speakers came back. When I am looking for 4x6's for the dash what do i ned to look at just the mounting depth or is there something else?
Car: 1983 Z28
Transmission: 5 speed
yeah definatly take your dash off and check the depth of your stock speakers, i put my tweeters from my componetents up in the stock 4x6 locations and was pretty suprized at how little depth there is up there. make sure you check it out before you buy your new speakers.
Car: '91 Firebird
I have a pair of Alpine 4x6 Type S's in my dash. I didn't have a problem fitting one in the passenger side, but I had to trim away some plastic for them to fit in the drivers side. It would still fit without trimming the platic, but the speaker was tilted forward slightly. Once you put the dash and speaker grills back on though, you can't notice.
Car: 91 formula
Transmission: t5
i have pioneer's in my firebird, but i dont know if there was any modifiying done when they were put in, because they were in there when i got the car, but it does not look like it, and they seem to fit in there fine
Car: 92 Firebird
Engine: 305 TBI
I used Pioneer TS-G4647's in the dash of my 92 Firebird. They bolted right in with no cutting or trimming. Hope this helps.
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I had the alpine 4x6s they have mounting bracket that gives enough space to mount them. They eventually sun rotted and the fiberglass clones blew out. I bought some memphis 4x6s cause of the lifetime warranty, they didn't fit but I used the brackets from the alpines and they worked fine then.
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
I have had a ton of different speakers in my car, and the only ones that don't seem to fit are the plate ones where the tweeter is separate from the woofer, like the BA plates, Infinity, etc.
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
You can get a 4" component set and make your own plates. Thats what I did when I replaced my Kappa plates.
Do you know where I could just buy the brackets?
Engine: 383 SBC
They came with my alpines but I'm sure if you go into a car audio store and start asking they probably know... I'll try doing some searches though... there just metal or plastic spacers really. They raise the speaker up so the magnet fits in the hole right.
Engine: 383 SBC
Might have just been a problem with my memphis's but I know my alpines came with them and they wouldn't fit right without them. I bet you could rig up a homemade one if the store didn't carry it.
Engine: 383 SBC
I believe I had the 4029s? Not sure on the model number I know they were 4x6 with the blue type cones. They were 2 ways I think... with around 80 peak watts.
Engine: 383 SBC
Kick panels are awesome too... but why not use the spot made to hold 4x6's in the dash?
Car: 1989 Firebird Convertible
Engine: 5.0 TBI
Because the kickpanels provide 10 times the sound quality over the dash location, and using both could actually hurt that imaging you can from the kick panels...
hey 92bird305 how do those pioneeers sound. There on sale at best buy and have heard pretty good things aobut them. Can they blow easy due to the low rms rating. sorry guys not much on speakers. any help would be cool
Car: 92 Firebird
Engine: 305 TBI
how about the infinity reference (non-plate) speakers? their rated at (135w 40rms). are they better then those pioneers at best buy(ts-4647s i beleive). Just looking for a decent front 4x6.
Car: 92 WS6 Trans am convertible
Engine: ls 6.2
Transmission: 4l80
Axle/Gears: 2.73's
ambainb
04-25-2016 09:21 PM
db057
08-11-2015 10:11 PM
Vintageracer
08-11-2015 08:13 PM
