I want an alarm that...
Car: 1988 Camaro Convertible
Engine: 355
has the following:
Remote Start
Power Windows
Power Door Locks
Power Trunk
As well has the following alarm features:
Pager
Ignition kill
one loud mother F*cker
If it doesn't have the windows I will live, but I want the rest. Not too worried about price, but want to stay under $500.00, but $550 isn't going to kill me. I am putting about $15k into my car all at one time and needless to say I want to keep it safe.
James
Remote Start
Power Windows
Power Door Locks
Power Trunk
Pager
Ignition kill
James
Car: Kitt
Engine: Classified
Axle/Gears: Moser/4:11
Good luck. I got my Viper Remote Start (just the remote start) and it cost me $300 installed. But if you install your alarm yourself, it might fit into your budget. Just thought I would add that.
Car: 1985 GMC Jimmy/1998 Chevy Malibu
Engine: 3.2L turbo Hybrid/bone stock 3100
Transmission: T-5 soon to be 700R4/4T40E
I don't know how the US pricing is, but 2 systems come to mind....
Viper 790XV, this is a combo unit (Security and remote starter), with out puts for door locks, trunk/hatch release.
The remote has an LCD screen that is more than just a pager, it will tell you in plain english what is going on, car running, shut down, door trigger, shock sensor, etc.... It also comes with the starter kill. This system has 2 aux outputs (one would be used for trunk/hatch release), the other could be used for a vent setting for the windows. I am using both outputs for window roll up and down on my bosses BMW.
The other system is the Crime Stopper CS2015, a lot of the same features as the Viper, combo unit, outputs for door locks, trunk/hatch release, etc. The Crime Stopper uses a dot matrix screen on the remote, uses icons that show up on the screen to inform you of what is happening.
The Viper is more money, but I do like that unit, I have installed dozens of them and they work very well.
I have probably installed more Crime Stopper units, and have had only one problem that was system related, kinda, there is a short cable that is plugged into the main module (brain) and then plugs into the antenna transceiver, which in this particular unit one of the wires (there are 3) had no connection, making the system unresponsive to remote commands. Swapped that cable and all was good.
Window automation will be extra, regardless of system used, requires an extra module that can be wired in.
These are the 2 systems I would reccomend looking at.
Originally posted by My86Firebird
both of witch suck when you compair them to the audiovox stuff IMO
Car: '88 GTA
Engine: TPI 350
Transmission: auto
Originally posted by The_Raven
Are you an installer by chance?
jacob
Guest
Posts: n/a
Well audiovox makes the Prestige line. not many people know that. here is a link to there upper end stuff (keep in mind you get what you pay for)
http://www.audiovox.com/webapp/wcs/s...y_prestige.jsp
take a look and see if you liek anything.... also keep in mind that not all the accessories are listed on the web site.
also keep in mind you may have the worlds best alarm but if you have a really bad installer its not going to do you any good.
Car: 87 T/A, 95 Dakota, 04 R1
Engine: LB9(blown), 5.2L 318, 998CC
Transmission: Built T-5, 46RH, Seq 6-Spd
Axle/Gears: 3.73 Swapped, 3.55 Posi, 530
everyone here has valid points. the only part that im missing is what does it matter of what company makes the "best" alarm we could go on forever debating whose got the best features, prices, add-ons, etc.... Someone could say the Viper 790xv is the best or that the Audiovox APS800 is the best but what does it really matter it comes down to two main things 1. The prices and 2. The reliability.
Guest
Posts: n/a
and don't forget how its installed. that would be my 3rd point
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
Clifford make a great system that should give you all the things you are looking for. look here for all your needs. http://www.clifford.com/main.asp I run cliffords in both my cars... great systems!! A little pricey, but will cover everything you are looking for, even the windows.
All systems have their strong points and not so strong points.
I used to be a diehard Clifford fan, until my AvantgardIII decided that it would do it's own thing, which always seemed to be contrary to what I wanted it to do. The rest of their systems from the same time frame were quite good, I did find their AvantgardIV system to be an odd one though, first year for the G4 technology, and again the rest of their systems were well thought out, but with the demise of the original company, now owned by DEI, at one point they were unsure as to what they were going to do with the name, so far they have kept it, but may be in teh next few years dropping that name along with a few others from the DEI line-up, this info is from a DEI rep (not the store reps, but the head DEI office). It is however undecided as to what WILL be happening but this seemed to be a very strong possibility, and with about 8 different line names and very similar product between each line name, I can see this happening in the future, not all at once, but a slow demise of names, and moving the products (if they were any different other than just model number) into the line names they plan to keep.
There are a few brands that I do not like, not because they don't well, not be because they are not reliable, but because the install can be long and tiresome, which brings up another point, if the system is "installer friendly" it will be more recommended than other systems, usually making install time shorter, which depending on how install is charged by the shop you deal with, can also bring the price down on that.
DEI has always had the Viper line, DEI bought Clifford.
Car: Right now 93 Lumina
Engine: 3.4 DOHC
Transmission: 4T60-E
I dont remember what company makes it, I know they are located in south africa. They make a alarm system that has flamethrower on each side of the car, if someone tries to break into your car it sets them on fire. I dont know about you but that is, in my oppinion the alarm system out there. Just my 2 cents
unfortunately anything like that is illegal in the U.S. It would be great though if you could set up something like a stun gun on the body of a car. I heard of someone doing that and killing a person that was trying to break into the car. Lets just say he wasnt a free man anymore. I think he got like 5 years for manslaughter or something to that effect.
Engine: 3.4 DOHC
are you sure?? i think its leagal here in texas i know you can shoot people here if they try to break into your house.
From what I have read/been told Texas does things right as far as theft is concerned, where the owner of the object getting stolen/broken into, has the right to defend themselves/property, but I do not know for sure, as I do not live there, but thinking about it. LOL
Engine: 3.4 DOHC
i think all you need to do is put a sign on your window that says
WARNING
Coming in contact with this automobile will cause serious burns
or something along does lines so you could say that they where worned
WARNING
Guest
Posts: n/a
I FOUND IT!!! The BEST alarm EVER you can't Beat this one!!!!! look!!!!!
http://myboringlife.com/big_black/guy.html
Best damn alarm ever!!!!!
Car: '89 rs convertible
Engine: ls1
Axle/Gears: 3.73 posi
audiovox makes a prestige alarm called city tuff( model no. APS-996) that will do everything you want including the pager.the only thing you would have get extra is the window roll-up modules.i prefer the DEI products because they use external relays which means the relays are easily replaceable in the event of a problem and DEI products ARE better quality.i've been a professional installer since 1984 and DEI products are on both of my vehicles. ( don't tell my boss that 'cause we sell prestige not DEI products)
Guest
Posts: n/a
Car: 1987 Chevrolet Camaro Z28 IROCZ
Engine: L98 350, mini ramed and camed
Transmission: T56 6 speed manual
Axle/Gears: 10 bolt 3:73 limited slip
i still like that one better :-D
Car: '89 IROC-Z Convertible & '91 RS
I have an Alpine Alarm with Keyless entry installed. I'd have to say that my favorite feature is the infrared sensor. Any time the alarm is armed and someone sticks their hand through the window or t-tops, it goes off. Pretty cool.
Engine: 355
Not sure I could set the up on my vert though. But when you think about it a convertible is the best place for it if someone decides to cut open my top.
Engine: ls1
sure you can,i've got an avital alarm with a DEI radar sensor in the console behind the shifter. it is a dual zone,if you walk up and look in the car,it will emit six warning chirps and the parking lites will flash. if you reach inside the car,it goes into full alarm mode.this sensor can be added to any alarm that has an instant neg trigger(not a door trigger).this is in an'89 rs 'vert.if you have a convertible,the sensor is almost necessary especially if you leave it with the top down alot.
buckeyecelt
09-24-2015 05:50 AM
