CD player fades out
Car: 08 Sierra, 08 Silverado, 91 z28
Engine: 5.3, 4.3, 5.7
Transmission: autos
CD player fades out
well fades out might not be the word for it. When i have the volume turned up at 32 or so the front and sail panel speakers turn off and the amp and sub stay running, it only fades for a few seconds but does it alot, so much that i get to the point that i turn the radio off. I checked the radio wires and all seem to be connected good, amp is connected good, only thing odd is the dash speakers are wired weird, the left and right are hooked together and have one line of + and - off of them instead of a + and - for each speaker. The CD player did not do this when it was in my other car. Also it works fine with the volume is at 27 or below. Someone help me its really getting on my nerves!
Transmission: autos
anyone???? i really want to fix it when i get home, someone give me some help to fix it, i cant stand listening to radio (stupid commicerals) and i cant even hear my cd with the volume down that low
Car: 1985 Camaro Z28/1989 Pontiac Trans Am GTA
Engine: 305 tpi/350tpi
well it sounds to me like maybe the speakers are run off of one set of wires. Possibly the CD player is seeing a load it cant handle? Try running new wires from the cd player to the speakers. Run a + and a - for each one, and run them off of the front channels of the cd player. Also make sure that you dont get positive and negative mixed up. Thats all I can think of for now, but hey, its worth a shot.
Transmission: autos
the only speakers ran off of one wire are the front two, i think that could be causing it to, also noticed that the cd player is pretty hot after ive been using it for like 5 minutes? is it over heating? i think the load thing is right though, thanks for responding
Car: '05 Pontiac G6
Engine: 3.5
Axle/Gears: Slow lol.
Either a load issue or possibly the power supply in the head unit is going bad, struggling to put power to the front speakers the way they are wired up. But as mentioned, I'd try rewiring the fronts first before taking the radio out and tossing it into traffic, lol. j/k :sillylol:
Transmission: autos
well some good came from me being mad at the radio and it being off, i found out that i have a messed up wheel bearing and a messed up ball joint, of 2 oppisite sides , oh well im gonna sell it tomorrow hopefully
I am almost positive that if the front speakers are running off of one wire, thats the problem. The headunit cant handle it and its overheating. Give them each their own wires, its will help.
blackz281le
01-11-2016 07:51 AM
Linson
10-01-2015 09:50 PM
