how good are the 680 watt Jenson amps
Car: 86 IROC-Z
Axle/Gears: 3.42s/posi/disc
i just got a 680 watt Jenson amp and 2 12 inch 400 watt jenson speakers in a box for pretty cheap. the amp is a 4 chanal but can be bridged also.
are these amps any good i herd it last summer when it was in a ford mistike or what ever car it was and it sounded pretty good to me. does any one no the rms of the amps.
the actual rms output of those amps are quite low...if its rated @ 680, then they rate it @ 170peak x4 (roughly) so it has maybe 50-75rms per channel of clean power.
Car: 86 IROC-Z
wat about when it is bridged to 3 chanals
im going to have it bridged to 2 chanals pushing two 400 watt jensons what is the rms out put when it is bridged
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
http://www.jensen.com/support_manuals.aspx
Select "Jensen Mobile" then look up the amp's model number to find a copy of the owner's manual. All the specs are in there.
db057
08-11-2015 10:11 PM
