I have subwoofers... sometimes
Car: 87 Camaro Convertible
Engine: 305 LG4
Okay, so I have two 12" Rockford Fosgate 400watt \ subs in the trunk of my camaro powered by a 2-channel 450 watt pioneer amp.
Well it plays fairly well but I've noticed if I try to take the music a bit high, the subs just cut out, like they're not there. To bring them back I have to bring the volume back down a bit and they'll start working again.
I didn't install the amp myself, so I'm not sure if it's a mistake in the wiring. Is my amp too low powered for the subs? Is there a setting I need to set on my amp? Is my CD player too low powered (I think it's 100watt)? Is this normal?
Please help!
Thanks!
Please help!
Thanks!
Car: 1998 Camaro
Engine: V-6 200 HP
Actually what might be happening is that your amp is going into thermal protection. You have to let the amp cool down before attempting to turn it back on. Thats why you can't turn your volume up that loud and or your amp is putting out too much power and you need to turn it down a bit. Did you set up your amp and volume control after you put it in? The input level control matches the output of your radio to the input of the amp. Make sure your input level on the amp in turned down all the way. Play a CD and make sure the bass and treble settings are flat. Turn the volume up slowly until you hear distortion. Now back the volume down just a bit. On the amp slowly turn up the input level control until you start to hear distortion. Then back it off a bit. Now your radio and amplifire are matched. Hope that helps Long huh
Engine: 305 LG4
Ok, I'll try that, although it's not becuase of overheating, I know that for sure. It's below-freezing weather over here and this happens all the time, I don't know how temperature really affects amps but maybe it's becuase it's too cold?
I'll try changing the setting like you said though, might help.
Thanks!
Thanks!
too small of guage wiring + crappy amp that struggles = system failure .... the cold shouldnt matter too much cause the average 2 channel amp looses about 40% of its juice due to the heat...thats why u dont need that many watts on a mono block amp to slam harder then a high watt amp Example: 300watt mono vs. 700 watt 2 channel amp = mono destroying the 2 channel
I have been having the same exact problem. I have a rockford fosgate 360a2 and 1 12" JL wo. I thought my remote wire was loose so I tightened that up and it still sometimes cuts out, mostly only when its turned up. Also I have 4ga wiring that splits into 8ga at a distribution block. The biggest wire the amp will take is 8ga so I know thats fine. Yes the ground is also 8ga, and its only about 12 inches long bolted right to the car in the bottom of the trunk. What could be causing this? If the frequencies on the amp were set wrong would it just cut out certain frequencies like that? Please help me. Thanks. Also what should I have the frequencies set at? I have low mid and high frequencies on my JVC KD SH77 and also have them on the amp, what would be the best frequencies for my sub? Also the amp is only turned up about 1/4 of the way, I already popped 1 WO with it and dont want to do it again. I listen to rap, country, metallica, godsmack, basically a huge variety. Thanks again.
I also have two 12" rockford XLC's and a rockford 500 amp. And have never had this problem, I wonder what makes my set up differnant than you guys?? I have you tried differnat amps to see if it does the same thing??
1 Post
Car: 89 Camaro RS
Engine: 2.8L V-6
Definately check the wiring first. Size does matter. I have a friend who was trying to run a Jensen amp (like 600 watts I think) and he was running power and ground off speaker wire! I almost smacked him! I told him he needed to upgrade to at least 8 ga. or else he would have a meltdown. He went to 4 ga. and has no pro...well, had no problems, his sh*t got jacked a couple days later.... But the wiring is nice!
Car: 1984 Pontiac Trans Am
Engine: 5.0L
Transmission: TH700-R4
the ohm load might be to low for the amp to handle as well. most 2 channel amps cant have below a 4ohm bridged mono load. i had a 2 channel autotek (actually very impressed with) that i sold to a friend. i ran it in 2 ohm bridged, but never had a problem ( i never listen to stuff that loud), yet he wired it up the same way but pushed it very hard and it blew on him. i would say check the ohm load and power wire size
Car: 89 IROC-Z
Engine: 355 TPI
A lot of people don’t realize that to small a gauge amp wire CAN kill the amp. Make shore you have the thick enough gauge power wire to your amp or you could blow the amp.
It would help to know what model amp you have. That way we could look at the amp's specs and see if there is a problem. It could be that you amp has a low current cut off where it tries to protect itself from insufficient current supplies. Also, it could be the temperature. Just because it is cold outside doesn't mean that the internal parts of the amp are. It could be something as small as a transistor that is overheating. That would only take a matter of seconds.
