DVC Subs & AMP wiring
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
my amp can do just about any configuration and ohms, just not sure how it all works. but wanna make sure im not making a mistake, on wiring or if what I want will work.
ok I added my amp/speaker info below, Im gonna run 1 12 DVC and 2 6x9s, can you give me a clue on some wiring. I really dont want 2 subs, like i got room for 2 anyways.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
FEATURES:
1000 WATTS PEAK POWER, 500 WATTS COUNTINUOUS POWER
4 LAYER SUPER HEAT RESISTANT DUAL ALUMINUM VOICE COIL FOR VARIOUS APPLICATIONS 4 Ohm + 4 Ohm
( 2 Ohm,8 Ohm 4 Ohm)
TWO TERMINAL 4 Ohm+4 Ohm
DUAL VOICE COIL COOLING SYSTEM: BUILT-IN BASKET AIR VENTILATION, FRONT VOICE COIL COOLING VENT SYSTEM
HEAVY STOCK NON-PRESSED COATED PAPER CONE WITH HEAVY DUTY JUMBO SURROUND
DUAL DAMPER
160oz. DOUBLE STACKED MAGNET!!
INDUSTRIAL BOLT CONSTRUCTION
ENHANCED ULTRA-FLEX LEAD WIRE
BUMPED AND VENTED CHROME FINISH T-YOLK & BACK PLATE
DUAL SILVER SCREW TERMINALS
Fs 30Hz
Qts 0.462
Qes 0.543
Qms 7.621
Vas 35 Liters
Xmax 16mm
Sd 0.0346m
Re 3.2 ohms
efficiency 88.62dB (1w/1m)
DUAL DAMPER
Fs 30Hz
Qts 0.462
Qes 0.543
Qms 7.621
Vas 35 Liters
Xmax 16mm
Sd 0.0346m
Re 3.2 ohms
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
- 4 Channel Amplifier
- Tri-Way Output Configuration:
4 x 300 Watts Output
2 x 600 Watts Bridged Output
2 x 300 Watts Front + 1 x 600 Watts Rear
- 1200 Watts Total Output
- Polished Chrome Finish w/ Plexiglass Panel
- Integrated Heatsink for Efficient
Heat Dissipation
- Remote Control Bass Booster
(0-12dB @ 60Hz)
- Fully Adjustable Electronic
Crossover Network
- Soft Turn On/Off Circuit
- 2 Ohm Stereo Stable
- Bridgeable into 4 Ohms
- Dual MOSFET PWM Power Supplies
- Variable Gain Control
- Remote Turn On/Off
- Hi/Lo Level Inputs
Heat Dissipation
(0-12dB @ 60Hz)
Crossover Network
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Of course I have no idea what im doing
screw the DVc , they are cool in all but i want 1 sub and just 1 amp, so it gonna be a single 15, I know somewhere in that info will tell me the general box size needed, and if it should be sealed or not.
anywho got a clue???
DHD and American Pro Make The Finest Chrome Cone Subwoofers On The Market. American Pro and DHD Are Two Of The Most Respected Names In Competition Speakers; These Subwoofers Can Handle Enough Power To Blow The Windows Out Of The Car Next Door.
15" Chrome Cone Model By DHD/American Pro. #NTX-6415 Woofer With Super High Polished Chrome Cone That Is Spectacular To Both Hear And See. The Epitome Of Power And Durability. The Cones On These Speakers Are Chrome Injected For Toughness; Lightweight; Weather Resistance; And Fast Constant Heat Disbursement. The Kapton Voice Coils Are Designed To Withstand Heat During Extended Hard Competition Play.
Cones Are Not "Chrome Plated" They Are Injected With Tough Durable Gold Finished Chrome In A Patented Process No Other Speakers Can Offer.
Model #NTX-6415
15" All-Chrome Woofer
700 Watts Max
350 Watts RMS
4 Ohm Impedance
Rubber Surround
Kaptan Voice Coil
Screw Style Terminals
Frequency Response: 25-800
Sensitivity: 90 dB
Reve (DC VC Res) 3.3000
Fo (Res Freq) 27.6090
Zo (Zmax at FO) 34.5649 Ohm
SD (Piston Area) 0.0855 (Sqm)
BL (Flux* Length) 13.6834 (tm)
NO (Ref Effcny) 0.7948
SPL (SPL at 1w) 90.9852
QMS (Mech Q) 5.0364
QES (Elec Q) 0.6166
QTS (Total Q) 0.5491
VAS (Acous Vol) 140.9972 Litr
CMS (Compliance) 135.7323 (Um/n)
MMS (Total Mass) 173.1605 Grams
MMD (Diaphram Mass) 158.5444 Grams
DHD and American Pro are both from the same MFG
Model #NTX-6415
700 Watts Max
350 Watts RMS
4 Ohm Impedance
Rubber Surround
Kaptan Voice Coil
Sensitivity: 90 dB
QMS (Mech Q) 5.0364
QES (Elec Q) 0.6166
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
You can do this with a SVC sub and two regular speakers.
Just make sure you don't follow that wiring diagram exactly. For instance...... your amp may be L+ / R- to bridge it..... but that'll give you the general idea.
AJ
AJ
Then you can also do this...... it's a little more complicated, but it'll allow you to run a DVC sub.
You'll need 4 high-pass (aka capacitors), and 2 low-pass filters (aka inductors or coils). If you get that amp and need to know what high and low pass filters to use, the amp company should be able to tell you IF they don't already have it in the Owners/Installation Manual.
AJ
AJ
Originally posted by The Man Metz
Yo AJ... who is the chick in your info? LOL
I want my wife to pose next to my car, but she hasn't yet. She's not opposed to it, but she's not anxious either. She's a lot prettier than she thinks she is. You know... the typical woman syndrome. They can be 5'6" tall, weigh 110 lbs. and say "I'm fat".
I'm hoping this gives her an incentive to make her do it.
AJ
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Hey thanks that helps a bit, but look at my pic. not sure how I would route the wires through the DVC on the one side bridged.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Anywho got a clue
Do you have an opnion on which I should go with??? stick with my original plan and the DVC sub or go with that reg 15 sub????
I dunno...... I myself like 4 ohm SVC subs. There just seems to be less moving parts to break.
DVC are more versitle for upgrading later. I guess it depends on what you plan to do later.
Here's another pic on how to hook up a DVC sub that has two 4 ohm voice coils.
The only drawback I see here is that you'll be presenting an 8 ohm load bridged (i.e., same as 4 ohms on each of the two channels of the amp.) This won't give you any extra power to the sub. It's when you bridge an amp into one 4 ohm voice coil that you reap the benefits of more power.
AJ
AJ
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Ok so if i go by your first pic, ill end up with 4 ohms, not quiet clear on the wiring there.
you saying or showing in the first pic to only hook up the amp to 1 of the voice coils on the sub and leave the other side unhooked???
could you draw out the 4 ohm one and show all 4 post on the sub???
I would rather go with a single 12in DVC sub than going to a 15, I would need to build a box for the 15.
Doing the above would be no different than doing this (which you can do to and it's a lot simpler.)
If you choose to do it this way..... MAKE SURE THE CROSSOVER IS ON!!!!!!! If not, the two coils could (actually will) get different signals and try and make the sub to two different things at once.
If anything, just to be safe I'd hook it up like the picture above. Or you can save a lot of hassle and just buy a SVC 4 ohm sub.
AJ
AJ
AJ
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
AJ
AJ
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
hey lots og good ideas man, thanks.
I do like the DVC but i know that 15 will punch.
think Ill just hafta build me a box for the 15. not sure on that though.
ported, sloted, sealed, sittin in bowl of lime jello.
db057
08-11-2015 10:11 PM
