which is neg and pos?
Car: 1987 "1991 Z" Sport Coupe
Engine: LG4
Transmission: TH700R4
hey, i wanna hook up my speakers tomorrow but im not sure which side the neg wire and the pos wire go to, there were no directions telling and it doesnt say anything on the speaker...ill show u a pic of what it looks like. and the monster cable that i got....the side with the stripe is the positive one right? i just want to get everything correct so i dont have to rip it apart and do it agian
thanks a lot
bub
thanks a lot
bub
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
grab some short pieces of wire and connect them to each terminal on the speaker. Grab an AA battery and touch each end of it with each wire. If the speaker pushes outward, the wire touching the positive end of the battery is the positive terminal. If the speaker pulls inward, they're reversed; ie. the positive on the battery is hooked up to the negative speaker terminal. This is the best way to be 100% sure what your speaker terminals are.
Location: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Generally the big one is possitive, and the little is the negative.
But to make sure, you can try the battery thing. It works.
Car: 1988 Vette; 1988 IROC Z-28
Engine: 350cid; 305cid
Transmission: 700R/4; 700R/4
Axle/Gears: 2.59; 2.77
The object is to correctly phase all the speakers; if some are reverse phased the sound vibrations will tend to cancel each other instead of reinforce.
This means that you just need to connect all speakers the same way.
Use the dry cell test to establish the speaker direction when using different speakers.
Engine: LG4
ok, i tried the battery thing and it worked and i hooked it up.
thanks for the help
bub
thanks for the help
bub
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Kewl, glad we could help....
gta892000
09-16-2015 12:37 AM
