stock radio short
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
stock radio short
the other day i hit the power button on the stock radio in my 84 t/a to turn it off and the antenna went down as it should, but now the radio doesnt come back on and the antenna never goes up. I checked my fuse box and nothings blown, what else could it be, any other fuses i need to check, i didnt see any behind the radio. Also it still is keeping time right though it did reset it after it was turned off and the car was turned off.
If it matters the radio is the stock tape deck with 3 band eq and the amp driven 5" subs in the sail panels. Thanx.
Car: 1986 Camaro
Engine: 383 Stroker
I had the same problem in my mom's caddy. I just replaced her stock deck with the stock one that was in my camaro from when I put my knew one in. I couldn't figure it out without some work, so it was just easier for me to switch decks since I had a couple of those sittin there.
-Eric
-Eric
db057
08-11-2015 10:11 PM
