12s or 10s?
12s or 10s?
Hey i have the kicker KX600.4 amp rated at 300w*2. im really confused on what subs i should buy....i was going to get the kicker compVR 12s but than a guy at the audio store told me to get 2 Oz 10s and he said they will sound better. What is a good sub get, to go perfect with my amp? i want something that will hit hard
thanks alot
thanks alot
I would get the 12" Vr's. They hit hard and clean. They will go great w/ the Kicker amp. Matching things is always better. Although don't put them in a ported box, although Kicker recomends it. Put these in a bigger sealed box and put them behind your back seat and people will hear you comin 3 blocks away.
Car: '91 Firebird vert
Engine: 305 TBI
Transmission: auto
i agree. you'll get better, cleaner bass response with 12s over 10s most times. and plus, for some reason systems always sound so much better when everything is from one manufacturer, i don't know why, they just do. here's the most important thing, though: get a good alarm.
Generally, it's better not to stick to one manufacturer for all aspects of your system, as some companies are better at one thing then others.
mike
Engine: 305 TBI
Transmission: auto
i don't know how to do the quote thing (somebody help me), so i'll just do this: djsexay you said you shouldn't stick with one brand and it doesn't make a difference.
see, i've had opposite results. i put a system into a buddy's car that sounded all right (mtx 400 watt amp and 2 punch 12s). then he got a punch amp (300 watt i think, but it was less watts than the mtx amp) and it sounded so much better. mtx is a great brand, so it can't be said that the brand was better. anyways, that's just my experience, i could be wrong, it's happened before.
Many regard Rockford as a better brand then MTX (I guess there are those who regard MTX as better then Rockford as well). Anyway, the increase in output had to have been from more power being delivered by the punch amp. Perhaps it was underated a bit more then the MTX ? Or perhaps the gain settings where higher, could be anything.
But the fact that they match or not match is only important when using speakers. For example, you generally want your front speakers to be the same as the back (if you use them), etc ...
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
DJSexay has a very good point. No one company has it down in all aspects of car audio. a couple may be close, but not entirely. you do however want to match front and rear speakers like previously noted also. keep some of the audio nuances alike so your ears are not being drawn to the rear. only matching you need to do is power wise.
on the idea of subs, i myself prefer 12s. they have a larger cone area, allowing them to hit a bit lower. i was able to fit my Type-R just right, but it would have been easier with a couple of 10s instead. either one works. i dont see much of a point for 15s or higher anymore (just my opinion) because the technology of speakers have allowed smaller drivers to push just as much air as their bigger brothers of yesturday. a great budget sub is the alpine type-r. i paid $130 for mine and i love it. you will be hard pressed to find a sub that can match its sq and spl for under $300
hmmm...yea i liked the kicker 12s better b/c i got to listin to the Oz 10s today and they no way compared....the kickers shaked the sealing of the room and the oz i barly herd them....but with the capatible speakers in front and rear...i didnt do that b/c i didnt know...i have pioneer 6*9s and rockford 4*6s now im on to the subs....but i always thought matching amps/subs were good b/c they were made for each other, but im not the type to make sure i do that...which ever is better i go for
thanks for the help again
