want a 91-92 Z28, B4C, or 5 speed
1 Post
Car: 92 B4C/1LE CHP camaro 06 vette LS2,
Transmission: iroc, 700r4, auto
i want an iroc Z again. preferrable a B4C or 1le, but will take an 87-92 Z28, must be a 5.7 or a 5 speed-or both (preferrable manual trans) modified is good! don't care about matching numbers. i can send pics of the MBZ, its a cool looking car and quite a sleeper. will run and drive fine with the 350 thats in it or be a screamer with the 383. will also trade one or both (car or motor) for a honda CBX, VTX, kawa 1700 or 2000, mean streak, victory.....hit me up.
TRADE: ??
1974 MBZ 450 SL hardtop/convertible has both tops. the body and interior are very clean. it has a 350 (SBC) chevy motor with a turbo 350 trans.-NO SMOG REQUIRED!! original MBZ chrome wheels, new blaupunkt C/D player with remote. the registration is on NON-OP status with no back fees due. the car is still a project---it needs the a/c hooked up and the steering is sloppy (needs ball joints/tie rods/bushings (about 200.00) and other minor repairs--drivers power window switch, high beam switch, i have the new switches-they just need to be installed...etc...(just little things). as it sits its worth about 3800-4300. the car has 108,000 original miles on it and i am in Bakersfield and would need you to deliver your car here and pick up the MBZ .
I CAN ALSO STORE THE MBZ HERE (FOR UP TO A YEAR)
AND:
383 stroker motor:
motor was a 350 roller out of an 89 iroc camaro now is a built 383 long block stroker motor (no intake or carb), 30 over, edelbrock aluminum heads, eagle rotating assembly, comp cam, pushrods and lifters, gold roller rockers, new flexplate and harmonic balancer........less than 3 hours of run time. i have about 4500 into this motor and i'm in bakersfield and would need the car delivered here and the motor picked up. will sell the motor outright for 2500.00
EMAIL ME FOR PICS: ron09517@aol.com
TRADE: ??
AND:
383 stroker motor:
Re: want a 91-92 Z28, B4C, or 5 speed
1991 B4C 5-speed, all original radio delete car, full documentation, e-mail correspondence from dealership that ordered the car new for showroom sneaking by the GM requirement to sell a B4C to police use, 17k original miles, everything works, four wheel disc brakes, original paint, original tires in garage, 3.42 posi-rear end. Yours for $25k.
1 Post
great! i'll send you a nigerian cashiers check for 50,000.00 and you can send me a western union money order for 10,000, keeping the extra 15,000 for your time.
Car: 91 Firebird
Engine: 6.0
I know you said a 5 spd, but what about a 6 spd car?
https://www.thirdgen.org/forums/cama...nvertible.html
