WTT: 1998 Camaro Z28 roller
Car: 88 Iroc
Engine: LM7
Transmission: TH 400
Axle/Gears: 12 bolt 3.91
READ THIS LINE FIRST: THIS IS A WANT TO TRADE AD
I just picked this car up. I like the car, I don't love it, so I'd like to see if I could get something I love
I am looking for a clean, late (88-92) 3rd gen Camaro/Trans Am roller that is setup the same as this.
1998 Z28 Camaro
Red/charcoal
t top
tinted windows
orig ls1 m6 car "no motor or trans "
5inch autometer monster tach w/ shift light
moser 9 inch rear
detroit locker
35 spline axles
4.11 gear's
slp lid and smooth bellow
ram air box
edlebrock torque arm adj
edlebrock pan hard adj
edelbrock control arms
comp adj rear shocks
subframe connectors
sjm abs/line lock delete kit
weld pro stars 15x10 / 15 x 3.5
28x12.50x15 mt et streets
black halo headlights
car has undergone most of the weight reductions allready ( everything removed is in box's though)..it has a clean and clear title
car has a4 pedals and harness and pcm in it as i converted it to an a4
comes with driveshaft,pcm,pcm harness, radiator and support, crossmembers,coil packs, everything but motor and trans, like said above it is now auto converted.with the correct piece's and done right
1998 Z28 Camaro
Red/charcoal
t top
tinted windows
moser 9 inch rear
detroit locker
35 spline axles
4.11 gear's
ram air box
subframe connectors
Car: 88 Iroc
Engine: LM7
Re: WTT: 1998 Camaro Z28 roller
nobody has interest in a clean 4th gen to trade for a 3rd gen?
Car: 90 Camaro RS
Engine: 2.8L v6
Transmission: 700
I'd probably trade in a heartbeat if my 3rd gen was clean. Needs minor body work n interior work
Car: 88 Iroc
Engine: LM7
supfolks...
I am looking for a third gen that is clean...
...and also one that sits the same as mine, meaning:
setup for drag racing
12 bolt or 9 inch rear,
suspension
cage is a +
cowl hood is a +
whatcha got?
suspension
cage is a +
cowl hood is a +
whatcha got?
junkcltr
08-02-2019 11:12 PM
GVMV
08-16-2015 08:01 PM
