!!!HELP!!! 1987-89 IROC-Z Wanted/Needed!
I know this probably isn't the place to put this but I've been looking for a '87-'89 IROC-Z Camaro (M5, T-tops, pw, most other options) for awhile now with no luck. I can find one with a AT but I'm looking for a manual. I love these cars and i'm trying to get one before school starts at the end of april. If anybody has one or knows someone who has one for sale please repond as soon as you can. The closer the California the better, but wherever works too. Thanks for you help.
Re: !!!HELP!!! 1987-89 IROC-Z Wanted/Needed!
I know that Chevy only bolted the manual to the 305 with the exception of the 1LE. It doesn't have to be a 350. A friend of mine is also looking for a 350 car too, if anybody has one. I'm more concerned with the manual tho. If anybody knows of any please let me know. I'm looking to get it ASAP. Thanks again. Almost forgot, I'm in Sacramento, California.
Location: Avatar: My 34' 1989 Scarab III w/ twin 454's (502's Started!)
Car: 1989 Wellcraft Scarab III
Engine: Twin 454's
Axle/Gears: Twin Mercruiser Bravo I's
Moving to wanted forum.
Car: 04 gtp comp group
Engine: 3.8 sc
i have for sale a 1987 IROC Z TPI Camaro
everything was professionally built and have recepts for everything purchased
this car has been gone through from top to bottom mechanically and just about
has had everything replaced. car runs like new, car has zero leaks and no
problems. car has clear title and no lean on it. also has up to date tags.
any questions please ask.
OVER 15K invested, have receipts for all.
asking $5500 o.b.o
MOTOR:
motor is still tuned port injection
305 bored, stroked and decked to a 340
3750 stroke crank
KB stroker pistons 9 to 1 compression
comp cams with hydrolic roller kit and comp mag roller tip rockers
mellings high volume oil pump
ARP bolts
lift rate on the cam duration @ .050 intake 212 exhaust 218
lobe lift intake .3250 exhaust .3300
everything replaced under the hood:
new o2 sensors, waterpump, new cap, rotor, wires, plugs including distributor
new motor mounts, all new sensors, hoses, egr, tps, various gaskets way too much
stuff to list.
TRANNY:
700 r4 transmission rated for well over 600 HP
completely rebuilt including new sensors, everything replaced with heavy duty
parts.
stg. 2 shift kit, 2500 stall, Kevlar sleeves, hd sprag, hd drive shell.
REAR END:
completely rebuilt
373 gears
new posi, all new bearings with seals and new u-joints
SUSPENSION:
hyperflex polyurothane kit
new coil springs front and rear
new swaybars link pins/bushings
new upper and lower ball joints
inner and outer tie rods
new center link
new shocks all around
new wheel bearings
EXHAUST:
BBK shorty headers wrapped in header wrap.
all new 3" exhaust with Y pipe
all in the stock location with new 40 series flowmaster
BRAKES:
new wheel cylinders, shoes, drums, hardware,
brake lines, calipers, rotors and pads
INTERIOR:
new heater core
replaced steering column
seats are out of a 96 firebird no tears
new carpet
grant wood grain wheel
have all interior pieces except for the headliner
have an extra grey interior
BODY:
extra set of t-tops (no leaks)
stock paint needs a new coat of clear
extra hood
TIRES:
in the front two 235/55 R 16"
in the rear two 295/50 R 16"
tires have under 3k on them, good tread
asking $5500 o.b.o
MOTOR:
3750 stroke crank
ARP bolts
stuff to list.
TRANNY:
parts.
REAR END:
completely rebuilt
373 gears
SUSPENSION:
new center link
new wheel bearings
EXHAUST:
BRAKES:
INTERIOR:
new heater core
new carpet
BODY:
extra hood
TIRES:
i have a 89 iroc z28 camaro with a new 350 and 700 r4 and lt1 and extra parts for sale $4500.00 fuilds havent been in either yet camaro needs finished put toghether call or text 765-431-7987 http://www.facebook.com/photo.php?fb...type=1&theater
not sure if this will help... http://london.kijiji.ca/c-cars-vehic...AdIdZ293560373
Car: 1987 iroc Z-28 5.7 TPI
Engine: 5.7 TPI
Hey There I am southern cal have a 5.7 blue 87 iroc z-28 just added 2200.00 exhaust sus,ca smog legal headman's $300.00, various new items 450.00,new stereo $1000.00. Dash is perfect,cold a/c, been appraised for over 10k, oh new falken tires
http://i193.photobucket.com/albums/z...8/P1010004.jpg
Car: 1989 rs
Engine: 350 stage one cam
Transmission: automatic overdrive
Axle/Gears: oem
i have one also with ram air 2 hood 411 posi rear end 3 speed slapshift stage 2 automatic trani 350 4 bolt main high performance engine 750 cfm edelbrock carb and intake and is 425 hp runs 13 seconds in the 1/4 mile very freaken fast has all the goodies headman headers frame extensions trani brace so much to list it is red in color...i live in ohio 43326 is the zip 419 673 0382 ask for ben would consider $4,500 also and has a nice stereo its a pioneer dash is good and cold a/c 17" rims american racing rims
Car: 1988 IROC Z
Engine: 5.7 litre
Axle/Gears: 3.27 Posi with 4 wheel disc brakes
