Wanted: Camaro near Chicago
Engine: SBC
open to anything. Auto, 700R4/TH350/TH400, etc. are pluses. T-Tops are good but hardtops work also, maybe even a droptop. I prefer IROC-Z & Z28s but will take anything from a 2.8 or 3.1 to a 5.7TPI or swapped motor car if i like it and its clean. RS works just fine also. No project cars, rustys or anything like that. I have cash in hand. Looking for something that I can drive daily and maybe bring to the track every now and again. If its under $5,000 and semi-local Post what you have available.
Car: 92 Jamacia Yellow Formula 350
Originally Posted by Exhausted1
open to anything. Auto, 700R4/TH350 are pluses. T-Tops a BIG PLUS! I prefer IROC-Z & Z28s but will take anything from a 3.1 to a 5.7TPI if i like it and its clean. I have cash in hand. Post what you have available.
you can reach me at 847 875 7472
They are all located in mundelein,il the most expensive on I have is $1500obo
chris
i've got an 89 iroc 350 t-top clean body needs front clip fenders are dented and nose is cracked, there is no rust and is very clean, has the normal rip on the drivers seat and it only has 88k on it.
Engine: Cammed 6.0L LSX
i've got a complete, and extremely nice 1989 IROC-Z for sale if you're interested. 92,xxx original miles, new paint, interior is 99% mint...etc ask anything you would like and i'll be more than happy to answer i'm wanting $6,000, and i'll even drive halfway and meet you...Chicago isn't too far from St Louis
85 Iroc
Well Ive got a 85 Iroc 80K original 305 TPI Auto T-tops and every option(yes even the really rare fog lights, power seat track, mirrors, deck lid and all that fun stuff. Runs and drivers perfect. Black on Black. Very clean for my daily driver asking $3800
Car: 1986 Trans Am
Engine: Mild 10:1 355.
Axle/Gears: 9 bolt
Iv got a 84 Z28 with T-tops and an auto 700r4. Its at teh shop getting a big general tune-up, because I bought it from my cousin and it had been sitting for a long time. 126k on it. My friend is selling a 305 with 104k on it for 150 that I could also get for you. Asking 2250
1989 camaro in chicago $1500
hey there exhausted i have a 1989 camaro w a 305 tbi...the color is maroon with chrome wheels..however it does have a broken tower strut mount and needs to be welded back on..other than that the motor is solid and the interior is clean...
Car: 84 camaro
Engine: 72 chevy 406 sbc
Axle/Gears: 3.42 eaton posi
i got a 84 camaro with 305 H.O rebuilt new 700r4 trans beefed up 3.42 gears new paint and grafx flowmaster exhaust much more more pictures in camaro photos section its midnight mettalic blue never had rust body has 98,000 miles,
motor has bout 8,000 trans has bout 5,000 on it it runs 13.8 in quarter smokin right rear tire $2,800
Car: 1989 IROC-Z
Engine: 316 C.I.D
Transmission: 700R
I HAVE BRIGHT BLUE METALLIC 89 IROC HARDTOP.17" IROC CHROME WHEELS...SS HOOD....9K ON REBUILT 305 ....$3500....CAR IS SOLID
MILWAUKEE WISCONSIN
MILWAUKEE WISCONSIN
are you up for a 4th gen?? I'm located in Southern (school) and Central (home) IL.....I'm selling my 96 camaro for $4500....It's got 195xxx miles on it....85xxx on the newer engine, everything runs perfectly fine and this is a really really clean car...$1000 stereo system in it...4 brand new tires....it's an automatic with the 3.8L V6....pretty peppy V6
Car: 92 RS Camaro
Engine: 305 tbi
Transmission: 5-speed
1992 rs camaro for sale....pics at link below. thanks
https://www.thirdgen.org/forums/cama...rs-camaro.html
Car: 83 Z28
Engine: Mild 383 Stroker
Transmission: B&M TH400 with shift kit
Axle/Gears: 3.73 Limited Slip
Got an 83 z28 with a 383 stroker and TH400 with a shift kit. Both motor and tranny have less than 1500 on rebuilds... I want $3500 for the car. Block was bored .030 over, decked, and clearanced for the steel 3.75" crank. KB flattop hypereutectic pistons 10.9:1 with 64 cc heads. Eagle SIR I-beams. Clevite 77 main and rod bearings. Plasma-moly rings. Running Hooker longtubes with no exhaust at the moment. Needs a good set of aluminum heads I think because I'm still running the stock LT1 iron heads with only 1.94/1.5 valves for the time being, if the car doesn't get sold before winter I'll probably put a set of aluminum Dart Pro1 heads on it. Weiand dual plane intake with edlebrock 750 electric choke. The cam is a Crane powermax hydrualic 234*/244* and .488/.510 lift. Rear-end is a 3.73 limited-slip with a custom driveshaft, crossmember for the tranny, and torque arm bracket on the back of the tranny. Body is in pretty good shape, only a small spot of rust on the drivers wheel well, just surface rust. Paint is white and is a 7 outta 10 at worst. A few gauges mounted with a 5" 160 mph speedo on the dash. Needs a new drivers side door panel, took the other one off to fix the window and its in less than desirable condition so it needs a new one. Located in SW Wisconsin.
1989 Rs Central Illinois
1989 RS w/ t-tops, 305, new tires, ball joints, 3 inch exhaust, borla tips, headers, magnaflow, sensitrac shocks and struts, runs and sounds like a beast!!! Minor damage due to the ice storm we had.. one tire is flat, but I will replace it. speedo stopped working shortly after I acquired it so miles are unknown, but when i purchased it it had a rebuilt engine and trans. 1500 will take it.
<center>
<a href="http://i80.photobucket.com/albums/j200/tumbling_mommy_05/camaro2.jpg" target="_blank">
<img src="http://i80.photobucket.com/albums/j200/tumbling_mommy_05/th_camaro2.jpg"></a>
<a href="http://i80.photobucket.com/albums/j200/tumbling_mommy_05/camaro1.jpg" target="_blank">
<img src="http://i80.photobucket.com/albums/j200/tumbling_mommy_05/th_camaro1.jpg"></a>
</center>
<center>
</center>
Car: 81 Chevy 4x4/86 T/A
Engine: 5.7L/5.0 (both modded)
Transmission: TH350/700R4
Axle/Gears: stock
Engine: SBC
Car: 1992 Z28 Conv.
Axle/Gears: 10 bolt, 2.73 posi
Engine: SBC
Dang man you're still looking for a car? I'm suprised you haven't jumped on any of the offers here in this thread. I'd go crazy if I didn't find a car within a month or two of searching.
Engine: SBC
BUMPSKI!
Car: 2000 SS
Transmission: a4
Re: Wanted: Camaro near Chicago
Did u find what u wanted yet? I have a 91 RS listed on this site and pics on
http://www.autotrader.com/fyc/vdp.jsp?car_id=229730641
